'67 Pro Touring Toronado
slkalo
TOA Membership Number: 263
Years Owned: 1967 Toronado deluxe
Postby slkalo » Wed Mar 02, 2022 10:57 am
Still putting the engine together, but completing work on the chassis, suspension and brakes. Pics to come, but have Edelbrock heads, aluminum low profile intake, Wilwood brakes, suspension rebuild with state of the art materials (polygraphite etc.), rear swaybar, rebuilt steering gear, new larger capacity fuel tank, etc.
roland
TOA Membership Number: 860
Re: '67 Pro Touring Toronado
Postby roland » Fri Mar 04, 2022 2:14 am
Pictures please, pictures :P
Roland TOA#860
Postby bcroe » Sun Mar 13, 2022 9:32 am
slkalo wrote:Still putting the engine together, but completing work on the chassis, suspension and brakes. Pics to come, but have Edelbrock heads, aluminum low profile intake, Wilwood brakes, suspension rebuild with state of the art materials (polygraphite etc.), rear swaybar, rebuilt steering gear, new larger capacity fuel tank, etc.
Brakes and chassis are very important. The switch pitch control could be upgraded.
How did you arrange for a larger fuel tank? Here I have used the tank from
a 5.7L diesel into a gas car, to get several extra gallons. Also calibrated the
gauge to be accurate to a gallon, to use that capacity. Bruce Roe
slkalo
Postby slkalo » Tue Mar 22, 2022 8:51 am
The tank I found is from a 1970- Olds 98, 26 1/2 gallon, and I had the trans rebuilt and also have the switch pitch module. The wheels are by Boyd Coddington.
slkalo
Postby slkalo » Tue Mar 22, 2022 9:04 am
TCE here in Phoenix can put Wilwood brakes on about anything. These are the adapters made to fit the Toro drum hubs.
slkalo
Postby slkalo » Tue Mar 22, 2022 9:22 am
Here is the completed Wilwood brake assembly, 14" rotors and 6 piston calipers, rebuilt steering box with a quicker ratio, all new urethane bushings, upgraded ball joints ,tie rods , sway bar end links, shocks. We also installed a rear sway bar and are working on rear suspension brake upgrades.
Postby bcroe » Tue Mar 22, 2022 12:01 pm
slkalo wrote:Here is the completed Wilwood brake assembly, 14" rotors and 6 piston calipers, rebuilt steering box with a quicker ratio, all new urethane bushings, upgraded ball joints ,tie rods , sway bar end links, shocks. We also installed a rear sway bar and are working on rear suspension brake upgrades.
Great upgrades for a 67. Is there an adjustable proportioning valve for front to rear Brakes?
Bruce Roe
Eightballz
TOA Membership Number: 826
Postby Eightballz » Wed Jul 12, 2023 8:25 pm
how you install a rear sway bar? Is that even possible with the toros rear axle with no coilovers?
Users browsing this forum: Baidu [Spider] and 8 guests
