Brand new Olds Toronado owner
Francois
Postby Francois » Fri Sep 13, 2019 5:48 am
On the first picture, yours seems to be connected to the transmission modulator line.
This is the answer that I got from a Facebook group :
Tim Hubler You're all wrong. That bolt was used in 1967 Toros equipped with the K-50 option, the Climatic Combustion Control air cleaner. That is the source of manifold vacuum that operates the vacuum controlled doors in each snorkel.
Then this post :
Ralph Hupfer OK guys, I stand corrected. IT is a factory bolt, on 67 with CCC. I have been in Olds parts from 69-80 and have never seen or had a call about it. I did not believe it. You gotta be kidding! Here's the part number for it. Ha
So I don't really know as I had so many different answers. But I have looked the manual and nearly every sections, I don't see any mentions of that bolt or any diagram where a vacuum line is plugged on that bold. But on the other hand, this is not the first picture of a 66 that I see with this bolt, for example, on the website of Sparky http://www.sparkyscarbs.com/October%20043.jpg
What to believe, what not, does it even matter ? :)
Tuco
Postby Tuco » Fri Sep 13, 2019 6:13 am
For what it’s worth, I don’t believe that bolt was for a 67 option. Ive seen it on too many 66’s.
My car didn’t have it but someone had changed from the original carb to a Holley. So it could have been there originally. The parts car had one and had the original carb. Same as Otto’s. My parts car had the transmission line attached to it but I know that wasn’t right because the metal tube was all bent around to reach it.
My personal opinion is that it doesn’t matter. As long as you have vacuum where you need it and ported vacuum to the distributor and all the others plugged you should be good.
Since I’m putting the original carb back on mine I’ve been looking for the Same info and I don’t think it exists. There were too many options and too many variables.
Just my two cents.
Francois
Postby Francois » Fri Sep 13, 2019 10:53 am
Ok thank you Otto and Tuco, this is what I found so far...
We all agree that the transmission line goes to that green input where I have a tee. Dashpot for the throttle goes to intake vacuum, so either on a plug at on the intake manifold as shown on the diagram, or to the red bolt that we have on the back. But it seems to need a check valve and I don't understand why... maybe to have a slower release ?
Then comes the subject of the distributor vacuum advance, many many websites are arguing about the fact that it should be plugged to the direct vacuum and not a ported vacuum https://classicoldsmobile.com/forums/general-discussion-33/ported-manifold-vacuum-advance-113536/, as it seems to make more sense to me, I'll just keep it that way and let it on the tee. I found a diagram where it is connected to the ported vacuum, but that's with the K-19 or K-20 option. Sadly I can't find one in a normal configuration.
So it seems like the ported vacuum on this carburetor is not used, as on many of the 7026250 it is either not present or plugged.
My goal here is to have a reference for anyone who wish to work on a Toronado and have everything right the first time :) So your contributions are more than welcome.
Annotation 2019-09-13 132738.png (273.4 KiB) Viewed 18167 times
Annotation 2019-09-13 104539.png (119.77 KiB) Viewed 18167 times
Annotation 2019-09-13 110046.png (200.82 KiB) Viewed 18167 times
Postby Otto Skorzeny » Fri Sep 13, 2019 11:47 am
Hi Francois,
I've never owned a car that doesn't have a carburetor.
All the vehicles I currently own have the dizzy advance coming out of a port on the front of the carburetor. '56 Cad, '79 F 100, '66 Toronado, '64 Galaxie 500, '76 F150. And as I recall, my '66 Mustang, '72 Monte Carlo, and '68 Camaro all had the vac advance coming off a port on their carburetors
My '66 Toro did not have a dashpot when I bought it. I've never bothered installing one and I've never had a problem. I considered adding one after the Q jet was rebuilt but there is no bad effect from not having one.
Tuco
Postby Tuco » Sat Sep 14, 2019 5:02 am
Thanks François. Good info.
Sleenda
TOA Membership Number: 774
normal dose of cialis
Postby Sleenda » Thu May 23, 2024 2:06 pm
2012 Sep 19; 103 6 1218 26 <a href=https://cialis.lat/discover-the-best-prices-for-cialis>best generic cialis</a>
Hiemype
TOA Membership Number: 995
tadalafil 10mg from canada
Postby Hiemype » Mon Jun 24, 2024 9:20 pm
Ashton, USA 2022 04 24 13 33 41 <a href=http://cialis.lat/discover-the-best-prices-for-cialis>cialis price</a> LASIK Surgery In Austin
AlmazBic
TOA Membership Number: 824
Что можно приготовить на перекус
Postby AlmazBic » Fri Jul 26, 2024 11:52 am
Сделайте полоску из семян чиа. Банан нарежьте кружочками и выложите сверху. Добавьте также миндаль, молотую корицу, кокосовые чипсы или кокосовую стружку
http://zyxmails.xyz
Postby xeror » Mon Jul 28, 2025 10:13 am
