Greetings from Miami !
- NewToro - 10a.JPG (165.96 KiB) Viewed 17503 times
Dave B.
Miami, FL
TOA # 99
Miami, FL
TOA # 99
- toro_mike
- TOA Membership Number: 4
- Contact:
Re: 1968 Toronado
Welcome Dave! That's a great picture! Nice rims
TOA #004, Webmaster
Forum Administrator
1969 W34 Toronado
TOA #004, Webmaster
Forum Administrator
1969 W34 Toronado
Re: 1968 Toronado
Thank you. It was a multi-year project to acquire these, blast and powder coat them, custom-fabricate spacers for the fronts, and custom-fabricate center caps. The end result is excellent!
- NewToro - 42a.JPG (100.08 KiB) Viewed 17478 times
- NewToro - 06a.JPG (172.94 KiB) Viewed 17478 times
Dave B.
Miami, FL
TOA # 99
Miami, FL
TOA # 99
- toro_mike
- Contact:
Re: 1968 Toronado
They look awesome... Great job. You should consider writing up your experience with creating these. I'm sure a lot of folks would love to read about it.
TOA #004, Webmaster
Forum Administrator
1969 W34 Toronado
TOA #004, Webmaster
Forum Administrator
1969 W34 Toronado
Graniteman
- TOA Membership Number: 70
Re: 1968 Toronado
Looks nice Dave!
Are the Western wheels the same backspace, etc. as factory wheels?
I know they where made for Toros and Eldos but that's about all I know about them.
Also are they the same width?
Thanks,
'66 Toronado
TOA #70
Thanks,
'66 Toronado
TOA #70
TOA # 70
Re: 1968 Toronado
Yes, the Western Wheel backspacing (and bolt pattern) is correct for both the front and rear hubs on my 1968 Toronado. However I modified my front hubs: a drum to disc brake installation. As a result, the Western Wheels did not fit the front hubs correctly. The disc brake calipers scraped the inside of the Western Wheel rims. This problem was solved by purchasing and installing custom-designed 1.5" adapters. And all four Western Wheels required extra-long lug bolts, which my mechanic special-ordered from one of his race car suppliers. Finally, my mechanic subcontracted design and manufacture of the custom center caps out to a metal fabricator.
- NewToro - 42a.JPG (100.08 KiB) Viewed 17417 times
- NewToro - 08a.JPG (143.02 KiB) Viewed 17417 times
Dave B.
Miami, FL
TOA # 99
Miami, FL
TOA # 99
