Jacob & Co Epic X Chrono
enala
Postby enala » Thu Apr 03, 2025 3:57 am
Compared to other chronographs of the same stage, Jacob & Co Epic X Chrono has the next advantages:
Unique appearance design and style
The iconic "X" element: The particular "X" shape is the well known feature, extending from the claw-shaped lugs to the dial. The first design language makes it stick out among many chronographs and also highly recognizable. luxury replica watches
Colored vitamin glass dial: The shaded mineral glass dial goes with exquisite details, including the double small dial structure with white marks, typically the hollow hour and second hands, and the red core chronograph hand. The colors are usually bright and layered, as well as the visual effect is unique and wonderful.
Large case and comfortable using feeling: The large diameter circumstance of 47 mm includes a bold shape, but by means of clever design, the sharp inclination of the lugs causes it to be adaptable to various wrist measurements, comfortable to wear, and showing a great atmospheric style. replica watches price
Excellent movements performance
Swiss-made column tire movement: Equipped with a Swiss-made automatic column wheel timepiece movement, the column controls structure is a relatively luxury and reliable design inside mechanical chronographs, which can guarantee the accuracy and steadiness of the timing function, exhibiting the brand's high level regarding watchmaking technology.
High frequency heurt: The movement runs with a frequency of 4Hz, that may be, 28, 800 vibrations each hour. The higher vibration frequency really helps to improve the accuracy of traveling time and make time way of measuring more accurate. replica Jacob and Co. Epic x
Powerful functional setup
Double small dial the right time and rotating inner band: The timing dial switches into a double-eye layout, using a 30-minute timing dial from 3 o'clock and a tiny second dial at on the lookout for o'clock. The layout is sensible and the time is clear. As well, the outer edge of the call has a diving scale spinning inner ring, which can be managed through the crown at 15 o'clock. It has a waterproof efficiency of 200 meters. It isn't only suitable for daily use, but also can meet particular diving needs. It has abundant and diverse functions.
Top-quality material selection
Multiple top quality materials: A variety of high-end supplies are available, such as 18K rare metal, white or black ceramic, grade a few titanium alloy, forged carbon fibre, etc ., to meet the tastes and needs of different consumers regarding materials, while ensuring often the durability and quality in the replica watches for sale.
Brand and celebrity assistance effect
Joint cooperation: Assistance with many well-known stars like Ronaldo and Messi to be able to launch joint watches. These kinds of collaborations not only enhance the brand's popularity and influence, but in addition add unique cultural associations and collection value for the watches, attracting the attention of several fans and watch enthusiasts.
replica Patek Philippe Twenty~4
replica HYT S1
Re: Jacob & Co Epic X Chrono
Postby xeror » Tue Jul 29, 2025 3:48 pm
Postby xeror » Tue Jul 29, 2025 3:49 pm
Postby xeror » Tue Jul 29, 2025 3:50 pm
Postby xeror » Tue Jul 29, 2025 3:51 pm
Postby xeror » Tue Jul 29, 2025 3:52 pm
Postby xeror » Tue Jul 29, 2025 3:54 pm
Postby xeror » Tue Jul 29, 2025 3:55 pm
Postby xeror » Tue Jul 29, 2025 3:58 pm
Postby xeror » Tue Jul 29, 2025 3:59 pm
