1966 Oldsmobile Toronado Steering Linkage Shock Absorber
Tomasz
Postby Tomasz » Sat May 23, 2015 7:39 am
HI.
Need buy this parts.
Who know where can i find it??
Any replacment??
Re: 1966 Oldsmobile Toronado Steering Linkage Shock Absorber
Postby Otto Skorzeny » Sat May 23, 2015 9:37 am
I think you mean the steering damper. Rock Auto has brand new ones for $15-$18. I'm sure Auto Zone, O'Reilly or Advance will have them, too.
http://www.rockauto.com/
1966 OLDSMOBILE TORONADO 7.0L 425cid V8 : Steering : Steering Damper
GABRIEL Part # 14010 S
Front
Part Image
- Non-stock item--shipping delayed up to 1 business days
$15.74
ACDELCO Part # 509604 {#88946545} Professional
Front; Steering Dampers
Part Image
$17.95
Tomasz
Postby Tomasz » Sat May 23, 2015 12:08 pm
on the rear i got 4 shock absorber
2 vertical i bought brand new
and 2 horizontal i need this
I cant found what type of absorber i must use
Postby Otto Skorzeny » Sat May 23, 2015 4:28 pm
Someone posted on this forum recently the part number for the horizontal shocks. It's the same as a VW Passat or something.
Postby Otto Skorzeny » Sat May 23, 2015 4:37 pm
Here's a link to the thread.
viewtopic.php?f=38&t=1247&hilit=horizontal+rear+shock
Fusick also sells the correct horizontal shocks.
Postby Otto Skorzeny » Sat May 23, 2015 5:21 pm
Fusick's is $70.
https://www.fusickautomotiveproducts.co ... atalog.pdf
Auto Zone's is $21.
I think I'd pick one up at the Zone and compare it to the original. Is the range of travel the same? You wouldn't want it to extend too far and damage something. If it isn't right, take it back and drop a C note with Fusick.
