1973 Toro for sale
List Toronados for sale here.
skokz
TOA Membership Number: 900
Years Owned: 1973 Toronado
1973 Toro for sale
Postby skokz » Sat May 12, 2012 11:59 am
Mileage unknown. Odometer currently says 08032. Runs and drives.
Car is fair condition for age and pretty close to original. Has two dents on passenger side.
Has surface rust on roof since roof was never treated after previous owner pulled vinyl top off.
Interior is rough. Needs seats recovered. Dash cracked from good desert heat. Needs trunk seal currently not one there. Windshield leaks at top on drivers side. Only the front two windows roll down but do have play and loose going up and down. The rear window motors work sounds like off track never took off to look.
New parts that i've installed.
Rear shocks.
Passenger side wheel bearing, lower ball joint and cv axle.
Fuel pump, egr valve and reman carb.
Intake and valve cover gaskets.
Oil sender switch, coolant sensor and heater control valve.
Wires, spark plugs, rotor, cap and reman distributor.
Upper radiator hose.
2000 obo and have clear title. Car located just outside of raleigh, nc. Here are some pics. Rest can be seen here:
http://s128.photobucket.com/albums/p172/skokz/Toronado/
