Gas gage
Kendicott1
Years Owned: Would like to aquire 1966,'67 or '68.
Gas gage
Postby Kendicott1 » Wed Aug 09, 2023 5:35 pm
I have a '66 Toro, the gas has started acting erratic. There's aprox. 1/4- 1/2 tank of gas but the needle has started to flucuate all over the place, it evens goes past Full & disappears up into the top of the gauge, but then comes back down & repeats the whole process! Any idea what the problem is, thank you!
Re: Gas gage
Postby Otto Skorzeny » Sun Aug 13, 2023 7:00 am
Check your ground connections first. Fluctuating gas gauge is usually caused by an iintermittent ground in the system.
Run a test wire bypassing the existing wiring and see if anything changes.
You may also have a float sticking or sending unit arm hanging up.
