'68 headlamp switch and A/C switch
Posted: Wed Jun 16, 2010 9:12 pm
by 68 Toro
My mechanic removed my 1968 Toronado dashboard to work on the A/C switch.
He removed vacuum lines from the headlamp switch but did not mark them. Now he is requesting a diagram. Hopefully somebody can describe the sequence of the vacuum lines on the headlamp switch or provide a diagram.
My old A/C fan speed thumbwheel switch never worked in the high position, which is desparately needed here in Miami. Last year I bought a "NOS" replacement. This "new" one works in the low and high position, but neither middle position. My mechanic suspects a faulty resistor or a bad "NOS" switch. Does anybody have the resistor part number, or any advice regarding the thumbwheel switch. I have the electrical wiring diagram which shows a "blower resistor" but no further information about it.
It has been awhile since I posted anything on this forum. Best wishes to everybody, and to everybody's Toronado.
Re: '68 headlamp switch and A/C switch
Posted: Thu Jun 17, 2010 9:12 am
by tadmin
68 Toro wrote:My mechanic removed my 1968 Toronado dashboard to work on the A/C switch.
If nobody responds by the time I get home, I will check my 68 service manual and scan the page with the vacuum diagrams for you. It's shocking the mechanic did not spend 5 minutes labeling the hoses. Any amateur knows to do that :roll:
Posted: Thu Jun 17, 2010 4:15 pm
by toro_mike
Posted: Sat Jun 19, 2010 1:03 pm
by 68 Toro
Thank you very much Mike.
Looking at the image you posted, I see that it is figure 11E-15.
Now I indeed found it in my '68 Olds Chassis Service Manual, which is sitting on my bookshelf.
I looked for it before, but was unable to find any reference to this particular system. That's because it is located in the chapter for Chassis Sheet Metal !!
Thank you again.
