1984 Vacuum reservoir
pgapapa46
- Years Owned: 1984 Toronado
My 1984 has the 2 port vacuum reservoir with only the line from the engine going in, just wanting to know if the other side goes to the hvac under dash, ( I still need to figure out why the climate control only throws out heat vacuum related I bet) or no hose goes there. I have the routing of the vacuum lines ( in picture) but don't see the reservoir included in it. Thanks for your help.
- 1984 vac.png (1.18 MiB) Viewed 12531 times
Re: 1984 Vacuum reservoir
Isn't that it labeled CAN on the front passenger side?
pgapapa46
No, that's the charcoal canister.
- roland
- TOA Membership Number: 860
If that vac reservoir is not on the label, it´s no part of the emission system.
Possible part of ac or door lock. You have no shop manual?
Roland TOA#860
pgapapa46
No, I don't but am hoping your right, the climate control only throws out heat right now. but a/c works fine.
pgapapa46
I bought the 35 buck Olds manual for 1984 well worth it.
