Fine example of a leaking Rochester Quadrajet. Toro smells in the garage like a gas station every time. Lot of black/blue smoke from exhaust after start - every time.
The 4bbl carb was remanufactured by Holley some times ago. But I do not believe they take a closer look to the plugs in it.
Left side of intake was flooded every time. The fat black/blue exhause smoke was the reason of to much fuel after every start.
No words...
Think, Holley did not do a closer look to the plugs. This is the real situation after unscrew the base plate.
Have to clean the hole and plug with brass brush (Dremel) and seal em with JB Water Weld. Hope that works...
Leaking Rochester Carburetor
- roland
- TOA Membership Number: 860
Roland TOA#860
- gmrocket
- TOA Membership Number: 880
Re: Leaking Rochester Carburetor
Roland - reach out to Greg “Sparky” Kalkhoff. He’s a Quadrajet restoration expert and did my ‘67’s 7027131 carb. JB Weld works on the well-plugs but it’s by no means permanent. I believe Sparky has his own technique that is truly permanent. Tell him I sent you!
http://www.sparkyscarbs.com/
Gregg L
TOA #880
'67 Deluxe
TOA #880
'67 Deluxe
Users browsing this forum: No registered users and 61 guests
