66 Toronado Wheel Bearings
torobob
Years Owned: 66 Toronado
Postby torobob » Wed Jul 18, 2012 4:41 pm
Does anyone have a source for front wheel bearings for the 66?
I just pulled mine apart. What a struggle. The bearing was frozen into the steering knuckle. I finally popped the ball joints and tie rod end and took the entire knuckle assy to the press. I then used a torch to heat the knuckle surrounding the bearing and was able to press the bearing out. Then you need to get the bearing off the hub. There is no way to get to it with a press, so I used a torch to slit the bearing in two places, clear down to but not into the hub spindle, and knocked it off.
Maybe you have a better way, but this works. I read an account of one guy cuttine the CV axle in half to get things apart. Can't figure that.
janeg
TOA Membership Number: 42
Re: 66 Toronado Wheel Bearings
Postby janeg » Sat Jul 21, 2012 8:55 am
We got two new 66 bearings from the company below in 2006; some say this is the only place to get 1966 bearings though I've heard of people being lucky in their locality. They are pricy but correct. Shipment was very prompt. The gentleman's name is George Bachlada (uncertain of last name spelling). We paid $456 including shipping and some other accessory (can't remember what) that was $21 each.
BEARINGS, seals for: axles, clutch, differential, kingpin, pinion, transmission, wheels, all years. Olcar Bearing Co, 135 James Creek, Southern Pines, NC 28387, 910-693-3324.**25-YR**
I hope the information is still good and you can get them for your 66! Please let me know if the info is obsolete.
You might also consider posting an ad in the club magazine (see our classifieds page) or post under Parts Wanted on this forum. Good luck!
Jane G
TOA #042
Membership Director
Schurkey
TOA Membership Number: 67
Postby Schurkey » Wed Aug 29, 2012 7:38 am
The obvious solution is to dump the front drum brakes, convert to disc brakes using the newer steering knuckle which also gets you the newer bearings.
I bet you could buy the parts for the same or less than the new bearings--but there'd be some extra labor in the conversion. Of course, the disc brakes are an upgrade in themselves.
xgecko
TOA Membership Number: 831
Postby xgecko » Wed Sep 05, 2012 1:11 pm
I second Shurkey's comment. After my experience with a '67 Delta 88 with drums I will never drive another front drum brake car again. The swap is fairly straightforward if you have all the parts, and the parts can be taken from any 70's Toro or Eldo as long as you take the knuckle and upper control arm together.
Disks are easier to maintain and far superior in performance. Given the cost of bearings for your '66 it is probably pretty cost effective a swap.
sworth66toro
Postby sworth66toro » Wed Sep 05, 2012 10:27 pm
Just got a Kanter catalog in the mail today and it list the front wheel bearing for the 66 toro at $199 each and $29 for the seal. Here is the link, http://www.kanter.com///productdetail.a ... 80&Prc=340
steven
will
TOA Membership Number: 1
Postby will » Sun Oct 26, 2025 11:07 pm
The activation of your Capital One card begins at capitalone.com/activate.
Complete your Capital One card activation online at capitalone.com/activate.
Activate your Capital One card online at capitalone.com/activate to start shopping.
capitalone.com/activate ensures your Capital One card is verified and ready.
will
Postby will » Sun Oct 26, 2025 11:10 pm
Easily set up your Capital One card by visiting capitalone.com/activate.
capitalone.com/activate provides a secure way to turn on your card.
Your Capital One card must be activated at capitalone.com/activate before use.
Fast, safe, and easy activation starts at capitalone.com/activate.
Activate your Capital One card digitally at capitalone.com/activate.
will
Postby will » Sun Oct 26, 2025 11:12 pm
capitalone.com/activate is the fastest way to enable your new card.
Use capitalone.com/activate to confirm your Capital One card is ready.
Unlock your Capital One card features at capitalone.com/activate.
capitalone.com/activate — Capital One’s secure site where cardholders quickly activate new or replacement credit or debit cards online by signing in and entering card details.
capitalone.com/activate is Capital One’s online card-activation portal for credit and debit cards
will
Postby will » Sun Oct 26, 2025 11:15 pm
capitalone.com/activate is where you validate your Capital One card.
Complete the card setup in minutes at capitalone.com/activate.
Secure your Capital One card access by visiting capitalone.com/activate.
capitalone.com/activate is the go-to page for Capital One card activation.
Make your Capital One card active and usable at capitalone.com/activate.
will
Postby will » Sun Oct 26, 2025 11:18 pm
With capitalone.com/activate, your card can be ready for spending quickly.
Activate your Capital One credit or debit card at capitalone.com/activate.
The Capital One activation service is available at capitalone.com/activate.
Ensure your Capital One card works properly by visiting capitalone.com/activate.
capitalone.com/activate allows you to switch on your card instantly.
