Replacing heater core
Toronadotrofeo
TOA Membership Number: 24
Years Owned: 1966 toronado
1981 toronado
1990 toronado
1991 toronado
1992 toronado
Postby Toronadotrofeo » Tue Nov 07, 2017 7:13 am
Hi all toro guys
I’m at the final stage of my toronado adventure
I have taken dash apart the cluster is out the ashtray and glovebox are also out
The only thing left is the steel part of the dash
I’m gong to replace the ducts because of the old moldy smell and replace the firewall insulation
I was wondering if this was a good time the dig Further and replace the heater core and at that point clean the heater box as well
Any suggestions
Postby bcroe » Tue Nov 07, 2017 1:12 pm
If the heater core is inside the car (like my 79), this would be a great time
to install a new heater core. I consider this a 19 year maintenance item,
because that is about when mine fail. Heater cores located in the engine
compartment are a whole lot less difficult to change. Bruce Roe
Toronadotrofeo
1981 toronado
1990 toronado
1991 toronado
1992 toronado
Re: Replacing heater core
Postby Toronadotrofeo » Tue Nov 07, 2017 2:06 pm
Thank you bcroe
It’s on the out side
But I totally removed all the duct work boxes and defrost to clean and disinfectant
Postby Otto Skorzeny » Wed Nov 08, 2017 8:31 am
Hi Bruce,
The FSM for my '66 Toro says that the hood has to be removed to replace the heater core on cars equipped with AC. It's silent on the procedure for non AC cars. Do you know if the core can be replaced without removing the hood on a 1966 non AC car?
I've been putting it off because I don't want to get partway into the removal of the plenum only to discover that it won't come out without the hood off.
Postby Doc Hubler » Wed Nov 08, 2017 3:27 pm
Otto,
I'm not sure why the hood would have to come off in either case, but I need to think about it (mine was obviously torn down all the way, so no issue). Possibly the reason is that you have to remove the hood hinge to get at the squirrel cage/blower motor and take it out.
One other reason I forgot to mention it's worth doing for those with AC is that you'll find plenty of rust on the firewall inside opposite where the evaporator goes from all the water condensation. The box comes appart in 2-3 pieces I think and is fiberglass. Clean it up and replace, but you'll have to replace the seals.
NRGF
TOA Membership Number: 40
Years Owned: 1969
Postby NRGF » Wed Nov 08, 2017 4:11 pm
I had to have the heater core replaced on my 69 Toronado with AC there was no need to remove the hood, just one bolt under the heater box just about impossible to refit.
NRGF
Years Owned: 1969
Postby NRGF » Wed Nov 08, 2017 4:15 pm
I had to have the heater core replaced on my 69 Toronado with AC there was no need to remove the hood. The only problem was one bolt under the heater box just about impossible to refit.
Postby bcroe » Wed Nov 08, 2017 5:48 pm
Otto Skorzeny wrote:Hi Bruce,
Sorry, I don't know what year E car heater cores moved from the engine compartment
to under the dash. Bruce Roe
Lipient
TOA Membership Number: 127
dapoxetine with alcohol
Postby Lipient » Mon Nov 11, 2024 8:17 pm
<a href=https://fastpriligy.top/>better business bureau online pharmacy priligy</a> 245 249, 2008
Casinosgigma
TOA Membership Number: 855
sugarhouse casino online q815sb
Postby Casinosgigma » Fri Feb 21, 2025 12:47 pm
Thank you. Quite a lot of posts.
casino online mГЈxico https://eseomail.com/wild-casino-review/ agen taruhan casino 368bet online
Play free casino games online crash casino game air casino online!
