1970 Toronado Parts wanted
Eightballz
TOA Membership Number: 826
Postby Eightballz » Sat Jun 09, 2012 4:40 am
hey guys...searching for several parts, here we go:
-steering wheel, deluxe, black, good condition
-lock set (doors, ignition, trunk, glove box, ...with keys)
-thermostatic vacuum water valve (comfortron only)
-idle dashpot
-rubber bumper to fender parts from passenger and drivers side (these are the parts you have in ebay) / and the rubber front end parts
-set of spare tire holddown and car jack
-antenna wiring harness
-brake metering valve (only good cond.)
-"T-Signs" on c-pillar (both)
-original rubber trunk mat?
-lower drain tubes / trunk / only good cond.
-GT hood emblem / good cond.
-rear set belt option / black only
-front grille / only good cond.
-bumper to frame brackets / where i can align the left and right front ends only from a car without crashes
-all screws that connect the hood to the hinges
-instrument panel without instruments..only the bare panel/ only black / good cond. / and for cars with cruise control and curtesy light switch / dont need the switches/
-small horizontal mounted rear shocks / only good cond.
-GT exhaust tips / good cond.
-rubber grommet where the throttle cable connects the throttle arm
-any full wheel hubcaps in good cond.?
-headlight and turn signal wiring harness, front / especially for me to see how it was originally wired
-fan shroud, no cracks
-battery support, only good cond.
1970w34
TOA Membership Number: 38
Years Owned: 1970 multiple
Re: 1970 Toronado Parts wanted
Postby 1970w34 » Sat Jun 09, 2012 7:27 am
Hey bro' it's Carmen, I have a good amount of that stuff if you're interested. Let me know if you don't get any leads.
CB
Return to “Wanted: Toronado”
