Dash Speaker on 66
oltoronut
Years Owned: 1966 toronado
Dash Speaker on 66
Postby oltoronut » Thu Mar 07, 2013 1:05 pm
Hi I have had the radio repaired on my 66 toro........But now I need to access the frond dash speaker.
Has anyone done this and is it a ^$$##% of a job........
Any info would be appreciated....
BJ
deaddds
TOA Membership Number: 8
Re: Dash Speaker on 66
Postby deaddds » Sun Mar 10, 2013 3:28 pm
Its not easy particularly if you have big hands. I replaced mine but cant remember exactly the sequence. I would get the shp manual out and it will at least help start. If I remember the radio needs to come out and the duct work but not necessary to pull the dash but it will make it easier. I got a new speaker from S and T electric in Minneapolis that fit exactly as you wont find the thin profile at an auto store needed to mount. Good luck. Pat
Postby Doc Hubler » Sun Mar 10, 2013 10:10 pm
I have mine out since I have the car entirely apart. The other commenter is correct; you'll have to pull the air distributor , and it is very hard to reach up in there. Everything is packed in tightly. I don't think you need to remove the radio -- that's in the instrument panel. Just unhook the speaker wire obviously. That speaker will be item #1 or #2 going back on the dash in the assembly process, if that gives you any indication about how difficult it is to reach it. Do use the manuel, as it will help give you a lay of the land. Remove ash tray, as it will help give some room. It is difficult to get the central defrost distributor out.
deaddds
Postby deaddds » Wed Mar 27, 2013 6:04 pm
BJ, sorry about the wrong lead. Its S&M electro tech 877 780 8261. I think it was Greg I dealt with but cant remember 100%
