Three wire relay.
taddpole
TOA Membership Number: 983
Years Owned: 69 Olds Toronado W-34
Three wire relay.
Postby taddpole » Sat May 11, 2013 1:37 pm
I need a new three wire relay for my ac system. When I took it to the ac shop they said it was bad. You can't turn the ac off with the switch it will only turn off once you turn off the car. Where can I get one?
hbarbee
TOA Membership Number: 1035
Years Owned: 1969
Re: Three wire relay.
Postby hbarbee » Tue May 14, 2013 5:07 pm
If you go to http://www.usapartssupply.com/olds.php and download the catalog you will find the part you need and probably some others.
HBARBEE 1969
