A/C only blowing out of lower openings
rollerball
Years Owned: 1966, 1970, 1974, 1977
Postby rollerball » Thu Jul 25, 2013 6:12 am
Hi,
i have a little problem with my 70 Toronado: The A/C and heater works fine but no matter what i do it only blows out of the lower center opening heating/cooling my feet.
Does anybody have an idea?
Regards
Thomas
1977 Cutly
TOA Membership Number: 1059
Years Owned: 1966 Toronados
1977 Cutlass Supreme
Re: A/C only blowing out of lower openings
Postby 1977 Cutly » Thu Jul 25, 2013 7:13 am
Have you tried poking with a coat hanger and see if there is a rodents nest blocking your comfort?
waterzap
TOA Membership Number: 1058
Years Owned: - 1967 Toronado
- 1978 Eldorado
Postby waterzap » Thu Jul 25, 2013 10:20 am
I had a similar problem once with a 76 Seville. The actuators in the dash work by vacuum. Took me a long, long time to figure everything out. You might have to check the actuators, and also check if you do get vacuum to them.
1977 Cutly
Postby 1977 Cutly » Fri Jul 26, 2013 7:35 am
waterzap wrote:I had a similar problem once with a 76 Seville. The actuators in the dash work by vacuum. Took me a long, long time to figure everything out. You might have to check the actuators, and also check if you do get vacuum to them.
Now that you mention it, my 77 cutlass only blew onto the floor until I found a vac line that wasnt hooked up. Then I could use the defrost.
do you hear any hissing from behind the dash when you move the HV AC controls?
