I cannot find the procedure or specs for this adjustment anywhere in the FSM.
My '56 Cadillac has a similar TV rod and the instructions are very specific. One or two threads either way changes the way the entire transmission shifts and how it downshifts at high speed.
What are the general specs for a '66 Toro? How much slack? Is there any Olds literature on the subject?
How Do You Adjust the Transmission Kickdown on a 1966 Toro?
Re: How Do You Adjust the Transmission Kickdown on a 1966 T
There is no TV rod on a THM 425. Kickdown is electric on the THM 425. You'd be adjusting a switch on the throttle linkage, back by the firewall. The same housing has the torque converter solenoid switch incorporated as well.
I took that switch assembly off of my Toro, replaced both switches with more-modern stuff. I put the kickdown switch onto the gas pedal bracket by buying a pedal, bracket, and self-adjusting switch from a '68--newer Toro.
The torque converter switch was replaced with a Bruce Roe electronics package that fits under the dash.
Yes, that's the rod I'm talking about. It connects the throttle to the lever on the kickdown switch.
What are the specs for adjusting that? What position is the lever on the switch supposed to be in at idle, etc?
Otto Skorzeny wrote:Yes, that's the rod I'm talking about. It connects the throttle to the lever on the kickdown switch.
You could check it with a 12V test light. The wire to the top tab on the
trans should show 12V at idle, and near full throttle. The wire to the
bottom terminal should only show near full throttle. You can just turn
the ignition on, no need to start the engine.
Those things are not particularly reliable. Even if they work correctly,
the performance can't match Schurkeys' approach. Bruce Roe
priligy need prescription
<a href=https://fastpriligy.top/>priligy dapoxetine 60mg</a> And you must sup plement it with a potassium supplement, or if on it short term you can get the potassium from food such as bananas
Casinosgigma
- TOA Membership Number: 855
mgm grand casino online betting a33hui
You definitely made your point!
pai gow poker online casinos https://hotgamblingguide.com/crash-crypto-gambling/ no deposit online casino free spins
online casino norwegian online real money casino ri online casino
Casinosgigma
Online casino usa real money fast payout c33ckr
Useful tips. Regards.
Unlicensed online casinos http://www.daongil.com/bbs/board.php?bo ... _id=691795 paf online casino!
Best ny online casinos https://www.kino-ussr.ru/user/QuinnBeckwith5/ tanpa modal online casino.
Play online casino malaysia http://xtp.jingyunys.top/home.php?mod=s ... from=space 21dukes try the best australian online casino games & bonuses.
Eis casino online https://www.honkaistarrail.wiki/index.p ... rlyCorbitt james bond casino royale online.
7 sins online casinos https://twsing.com/thread-373688-1-1.html casinos del litoral online.
https://jarduino.ru/2019/09/11/exp-12-l ... mment-1536
https://darkmorlarp.com/forum/showthread.php?tid=63227
https://nauc.info/forums/viewtopic.php?t=20818959
https://forum.graylite.com/viewtopic.ph ... 09#p469009
https://bbs.sinbadgroup.org/index.php?x ... ost-254470
Casinosgigma
Casino royale novel online s69wtj
This is nicely expressed. !
New york online casino https://kr.meyer.com/bbs/board.php?bo_t ... _id=226968 casino games online roulette.
Fastest withdrawal online casino canada https://www.mazafakas.com/user/profile/6176591 888 online casino customer service number!
Casino with real money online http://www.so0912.com/home.php?mod=spac ... from=space how to win at online casino!
Best online casinos bangladesh http://kangwonyeongnong.com/bbs/board.p ... id=1008099 casino slots online philippines.
Gta online casino heist bugged http://freeflashgamesnow.com/profile/36 ... tsukoRason online casino with starting credit 2025!
http://gkzmoney.ru/post1101307.html#p1101307
https://hardcoredumper.com/showthread.p ... #pid225895
https://www.vimalakirti.com/tc/yybbs/yybbs.cgi
https://zvenigorod-info.ru/component/k2 ... vedenskoe/
https://orpiment.xyz/thread-80789.html
Casinosgigma
Tropica casino online login r66qhb
Truly quite a lot of beneficial information!
Tango casino online http://www.yogizogi.kr/bbs/board.php?bo ... id=1032902 online casino with direct debit.
Slotomania casino free online https://noooo.tv/bbs/board.php?bo_table ... _id=156677 gta online how to start diamond casino heist.
Rtg usa online casinos https://yogaasanas.science/wiki/Top_Onl ... es_Reviews bank online casino chargeback.
Best gambling online casinos https://porno-gallery.ru/user/AlbertoSligo804/ thailand online casino!
Best canadian online casino sites https://www.feedpost.co.kr/bbs/board.ph ... id=1131199 online casino illinois reddit!
https://bbs.sinbadgroup.org/index.php?x ... ost-279674
https://the-smallerboard.net/index.php? ... 96.new#new
http://www.e-kou.jp/xxyybbs/2yybbs/yybbs.cgi
https://www.ircforumcu.net/zsohbet-fm/1 ... #post33947
http://old.pokvesti.ru/forum/viewtopic. ... 5&t=749777
Casinosgigma
Deutschlands bestes online casino golden tiger 1500 gratis g47epp
Really plenty of amazing info.
Las vegas casino online betting https://ohana.co/2019/05/15/%e6%95%b4%e ... %ef%bc%81/ hi lo online casino!
Real money online casino https://gpyouhak.com/gpy/bbs/board.php? ... id=1137752 colombian online casinos.
Best apple pay online casino sites https://humanlove.stream/wiki/User:NonaHollingswort online casinos croatia.
Casinos online mastercard http://freeflashgamesnow.com/profile/36 ... GKRod86348 new online casinos march 2025!
Casino online platform http://www.svetonic.ru/bitrix/rk.php?go ... /yybbs.cgi best online casino uk 2025.
https://forum-tver.ru/threads/12-stulev ... st-1329795
https://oke.zone/viewtopic.php?pid=1410480#p1410480
http://primeos.ru/node/5?page=314#comment-31519
https://www.mmopro.org/introductions/16 ... post215249
http://seneoudom.com/viewtopic.php?p=53932#p53932
Users browsing this forum: will and 5 guests
