Hi guys...love the forum so far. I have AC and heat but the air only comes out at the floor and windshield no matter what setting its on. I'd love to have my AC coming out of the personal vents. Any ideas what I should be looking for? Could it be a vacuum problem?
Thanks,
Dan
AC and Heat
AC and Heat
- toronado.jpg (64.35 KiB) Viewed 9137 times
Re: AC and Heat
I had that same problem on my 1966 and a vacuum hose had come off the valve/actuator behind the dash in the area of the radio. I was able to reach under the dash and reattach it. After that, I started getting air out of the vents.
Re: AC and Heat
hherryjohn wrote:I have samples and can get you pictures. These are probably at least grade 6-8 bolts and have a special taper/thread length for it's function. I DOUBT you can get them OEM anymore....but it's possible to find them off donor cars or possible from cross application use. Let me know if you need further assistance.
Huh? Special bolts for...what?
Re: AC and Heat
It's a spam post.
