Will '67 Toro wheels fit a 66 Toro?
paxtonshelby1966
1966 Mustang
2014 Mustang GT
Postby paxtonshelby1966 » Tue Sep 29, 2015 2:32 pm
Hi guys - like the title says - can someone tell me if '67 Toro wheels will fit a stock, 4-wheel drum brake '66? I have no idea if the '67 wheels are from a front drum or front disc car.
Also - are the wheels from a '67 front disc / rear drum Toro identical? ( front vs rear )
I came across a set of 4 chrome wheels for sale and the ad says they fit '66/'67 Toros, but I figured I should ask you guys first. Price is $275 for all 4. Is that a good deal if they're straight and chrome is in decent driver shape?
Thanks!!
Re: Will '67 Toro wheels fit a 66 Toro?
Postby Otto Skorzeny » Tue Sep 29, 2015 7:37 pm
I'm pretty sure the 67 wheels will fit a '66 but not the other way around.
The disc brakes are the reason for this.
One thing to also note: '66 trim rings will not fit on '67 rims. The rims are made differently. Somewhere on this forum I posted photos of the different wheels.
As for the price, that sounds like a bargain for any kind of wheel for any kind of car.
Postby Otto Skorzeny » Tue Sep 29, 2015 7:50 pm
The chrome wheels were only chromed in the center from the factory. The normal trim ring is used with them.
viewtopic.php?f=7&t=1403
Here is another thread that deals with wheels w/pix.
viewtopic.php?f=7&t=1148&start=20
Valve stem location is also different between '66 and '67
69W34
Postby 69W34 » Wed Oct 07, 2015 7:01 pm
This is incorrect the valve stem is not different between the 66 -67 wheel, however it is different between the drum and disc wheel. The 66 67 drum wheel will fit an 66-69 with drum brakes the 67 and up disc wheel will fit 66 -78 with drum or disc. Disc became standard by default in 70.
Postby Otto Skorzeny » Thu Oct 08, 2015 3:55 pm
Sorry I meant to include that regarding drums and discs.
The '67 drum wheel is the same as the '66 wheels, correct?
Postby Doc Hubler » Fri Oct 09, 2015 6:52 pm
yes, the drum wheels are all the same, certainly for Gen I.
paxtonshelby1966
1966 Mustang
2014 Mustang GT
Postby paxtonshelby1966 » Mon Oct 12, 2015 6:52 am
Thanks guys - but my question now is...if I come across '67 disc wheels...will they work on my '66 ( stock drums ) with my '66 trim rings and hubcaps?
Postby Otto Skorzeny » Mon Oct 12, 2015 5:28 pm
66 trim rings will NOT work on '67 disc brake wheels. The valve stem is in a different place and the width of the two trim rings is different.
Toro wheel, 10 hole.jpg (55.78 KiB) Viewed 19033 times
Toro wheel, 7 hole.jpg (63.61 KiB) Viewed 19033 times
Toro wheel,1967, 10 hole.jpg (141.64 KiB) Viewed 19033 times
Postby Otto Skorzeny » Mon Oct 12, 2015 6:47 pm
Here's a site with tons of pictures of different Toro wheels and information about them.
http://www.breznick.com/toronado/wheels/
paxtonshelby1966
1966 Mustang
2014 Mustang GT
Postby paxtonshelby1966 » Tue Oct 13, 2015 12:30 pm
Thanks Otto - that answers my question perfectly! So the valve stem location is the key. Plus I think the reinforcement plate on the drum wheels would also confirm. If I bring one of my wheels with me I can't go wrong. Thanks again buddy!
