66 toronado
- Years Owned: 3 1966 toronados,1970 buick 225 covert. 1964 olds cutlass
66 toronado
i got another 66 yesterday,like i need one more? the guy said the motor was good ,but it takes a gallon of water in 5 miles.and blows out white smoke,i wonder if its more likely a head gasget or bad head or block.thank ,mark
- toro_mike
- TOA Membership Number: 4
- Contact:
Re: 66 toronado
mark wrote:i got another 66 yesterday,like i need one more? the guy said the motor was good ,but it takes a gallon of water in 5 miles.and blows out white smoke,i wonder if its more likely a head gasget or bad head or block.thank ,mark
If you leave the car sitting, take out the spark plugs and see if any cylinders are wet or have pooling in them. That may help narrow down where the leak is.
Then, I'd go for the easy thing and pull the heads. Hopefully it's just a bad head gasket on one or both sides. It could also be a cracked head as this was a problem I had in the past.
Good luck. Keep us updated!
TOA #004, Webmaster
Forum Administrator
1969 W34 Toronado
TOA #004, Webmaster
Forum Administrator
1969 W34 Toronado
Users browsing this forum: Google [Bot] and 9 guests
