Hello from Germany!
Re: Hello from Germany!
Postby Otto Skorzeny » Sun Aug 25, 2019 5:48 pm
I never check it. It's not really necessary on "modern" vehicles.
Postby bcroe » Sun Aug 25, 2019 7:00 pm
Jelonek wrote: I worked last time with my friends on old Chevy from 1965 and 1966...
how often do you check the valve clearance...
Is the clearance for the in .. and exhaust the same ? 0,001 -0,003"
I am quite certain this car used hydraulic valve lifters, which do not require
adjustment. Bruce Roe
Jelonek
Years Owned: 1
Postby Jelonek » Mon Aug 26, 2019 8:56 am
Thanks, guys for a quick and expert answer. Now I'm a little smarter too.
Jelonek
Years Owned: 1
Postby Jelonek » Sun Mar 29, 2020 6:59 am
Hi everybody!
couse of aktually situation :evil: :? I have a time and I want to put a new casget and instal intake manifold.
what is the torque for screws ??? I can´t find it in internet ..
thanks a lot! and be careful !
Jelonek
Years Owned: 1
Postby Jelonek » Sun Mar 29, 2020 7:00 am
now it looks like this
Postby Otto Skorzeny » Mon Mar 30, 2020 7:31 am
Hi Jelonek.
Have you not purchased a 1966 Oldsmobile Chassis Service Manual , yet?
https://www.ebay.com/itm/1966-OLDSMOBIL ... XQDfdRo7zG
Page 6B-47 lists all the torque Specs for the engine.
Cylinder Head to Block 80 foot pounds
Intake Manifold to Cylinder Head Bolts 35 foot pounds
All the above bolts must be dipped in oil prior to installation for correct torque readings
Jelonek
Years Owned: 1
Postby Jelonek » Thu Apr 02, 2020 12:50 am
Thanks a lot! Otto, after your mail I found this to :cry:
I hope to finish my work today und to start the engine again .
Postby Otto Skorzeny » Thu Apr 02, 2020 5:35 am
What happened, Jelonek? Why are you doing this work? Did you blow a head gasket?
Jelonek
Years Owned: 1
Postby Jelonek » Fri Apr 03, 2020 2:42 am
no... nothing bad but I had a problem withe the intake-gasket at the front , lekage, leaking,
last summer a got a new gasket and the work ist not so complicated, even ignition don´t musst be disassembled,
the Intake is a very heavy, so I built a pulley to put it with feeling ...
so today i want to refill the coolingsystem and drive again :roll:
Jelonek
Years Owned: 1
Postby Jelonek » Fri Apr 03, 2020 2:51 am
some pics after the work
