1966 Toro headlights trouble
harascho
Re: 1966 Toro headlights trouble
Postby harascho » Sun Feb 08, 2015 12:37 pm
And now the solution:
harascho
Postby harascho » Sun Feb 08, 2015 12:39 pm
The drawback is the lamps will close slowly because VAC is bled through the headlampswitch and there is a little longer hose than in the version with that special T-checkvalve -piece..
Harald
MikeB
Postby MikeB » Sun Feb 08, 2015 9:28 pm
The switch vacuum only raises the lights (when on) and unlocks the lights (when off). The check valve in the tee closes with the vacuum to open the lights, and the check valve opens when the vacuum disappears to allow it to bleed the canisters and close.
Adding a regular tee inline with the canisters and putting a one way valve on it worked for me, after I found the line pinched behind the battery.
Mike.
MikeB
Postby MikeB » Sun Feb 08, 2015 9:41 pm
I used one of these.
http://www.summitracing.com/parts/rnb-4 ... fgodc0YAoQ
Better than drilling into a rare switch.
Mike.
accictape
TOA Membership Number: 411
cialis company information
Postby accictape » Mon May 27, 2024 6:21 pm
<a href=https://cialis.lat/discover-the-best-prices-for-cialis>buy cialis 5mg</a> B BrdU positive cells for both transgenic and WT mice counted and expressed as a ratio of positive nuclei to the total number of nuclei counted percentage
Lipient
TOA Membership Number: 127
priligy senegal
Postby Lipient » Thu Nov 07, 2024 5:44 pm
<a href=https://fastpriligy.top/>priligy tablets</a> clavulanate vibramycin doxycycline Although equities rose on Tuesday on hopes the first partialshutdown of the U
Users browsing this forum: Palmaarins and 8 guests
