I do know that there are several factors that can explain why the car gets such good mileage. For one thing Oldsmobile engines are particularly efficient for the time. Then there is the lack of emissions controls and the high compression ratio.
Finally, when I get 18 MPG, I am driving in something of a hypermiling kind of way. I accelerate smoothly and drive at moderate speeds. Not too hard, really, as it is very relaxing and the car somehow encourages both aggressive driving when in the mood and smooth, relaxing driving when not.
I have yet to determine highway mileage, and when I say city I really mean country road which is not so much stop and go as much as it is 40 - 60 MPH for extended periods.
So I suspect it depends on your driving style to some degree.
fuel efficiency
Re: fuel efficiency
Re: fuel efficiency
A thought occurs... xGecko, did you replace that speedo gear yet? If not, then our odometers are off as well, wich would show a higher fuel economy than actual by the same margin.
Our speedometers are off by you thought your speedo was off by about 10%, one of those speed-sensing sogns aid I was going 34 when speedo saod 40, so that's nearly 20%. When you do the math, it works out that we've probably got the same economy as everyone else...
Re: fuel efficiency
No, I have not yet replaced the gear, but I am not going by that measure. I am not at an official mpg rating right now, I am just going by what I did years ago and the length of the drives I was doing. I used the route mileage and the amount of fuel to generate a rough mileage value.
Next year I will do a proper test once I get the fuel injection installed.
In the past I was able to calculate it pretty well, I got around 18 average if I did not get aggressive based on known distances similar to the above method.
I have a number of regular cruise routes mapped out now where I live and given the length of the drives and the amount of gas I am using it is pretty much the same. Go easy and these motors will give great mileage, get on it and you will go broke fast...
Users browsing this forum: Baidu [Spider] and 12 guests
