Multipoint EFI for my 1969 Restomod.
Mikel
TOA Membership Number: 100
Re: Multipoint EFI for my 1969 Restomod.
Postby Mikel » Fri Jan 07, 2022 1:46 pm
Any updates? 8-)
Postby xgecko » Fri Jan 07, 2022 3:12 pm
Yep... sometime last year I had the unfortunate luck to have the bearing for a Timing Chain Idler Gear grenade in my Cadillac CTS Wagon so that put the kibosh on my budget. I need to mill the holes in the Toronado Intake so I can weld the bungs in, and now I have to address the Cadillac first. Before I buy the Milling Machine needed for the Toro I have to buy a Lift so I can swap the engine in my Cadillac.
So now the plan is to put the Holley Sniper I was running back on and hope that the Air Hat I was using is what caused most of my issues. If so then I can drive it for the summer while I fix the Cadillac, otherwise I may have to complete the work first.
The Toro is occupying the bay where the Lift will be installed so I need to be able to move it to use the space.
I guess all of this comes under the heading of "Life is what happens while you are busy making other plans"
Postby Otto Skorzeny » Fri Jan 07, 2022 7:14 pm
All those are pretty good problems to have, actually.
It keeps you out of trouble.
Mikel
Postby Mikel » Fri Jan 07, 2022 8:34 pm
Bummer. Good luck.
Postby xgecko » Sat Jan 08, 2022 7:37 am
Be that as it may, I really would rather be in trouble than have to put a new engine in the Wagon... it came at an absolutely horrible time when I have the cash but cannot allocate it due to being in the process of taking a business from part time to full time and not quite being there yet...
Hoping to get it going this spring.
Postby Otto Skorzeny » Sat Jan 08, 2022 4:42 pm
My previous response probably seemed weird and lacked context.
I meant that you have the ability and the means to make the repairs and you have a backup plan for the Toronado. It's better than a total loss on the car, serious health problems, etc.
Cars can be fixed and its generally fun to fix them.
Postby xgecko » Tue Jan 11, 2022 6:40 am
OK, that makes a lot more sense. I just paid my estimated tax bill, been looking at that for some time and it turns out I have that horrible problem of having made a bit more last year than I expected to.
Once all that is sorted out and I have a solid grasp of my revenue I will hopefully be able to start making progress on these projects. I decided to try putting the old EFI back on in the hope that it will work well enough for the season - that will reduce the cost considerably but having my Heat Pump go out was not part of the plan.
Yes, there are worse problems to have, but right now I would appreciate fewer problems. As I noted: Life is what happens while we are busy making other plans...
69OldsSpeed
Years Owned: 1969 Oldsmobile Cutlass S
1967 Oldsmobile Toronado
Postby 69OldsSpeed » Mon Feb 27, 2023 9:05 am
xgecko wrote:I am using, as noted in my OP but apparently not very clearly, the RPM Aluminum Toronado Intake. I will be welding in the bungs that come with the kit - I originally planned to use the Bosses cast into the Manifold, but they are vertically oriented and I need to angle the injectors at 30 from Vertical to aim them into the intake port.
Hello XGecko. I know this thread is old, but you mention an RPM aluminum Toronado Intake. Is this an Edelbrock RPM product or the Mondello intake? A part number would be awesome. I am contemplating an engine rebuild.
Postby xgecko » Mon Feb 27, 2023 12:36 pm
It is the same as the Mondello and was designed by Gary Roberts. At this time it is available from Mondello and Applied GMC (Link below).
Price has pretty much doubled.
https://www.gmcrvparts.com/product-p/455-gm08-006-27.1.htm
69OldsSpeed
Postby 69OldsSpeed » Mon Feb 27, 2023 8:27 pm
Thank you. I had delusions that there was a more cost effective source. Maybe I’ll stick with the old Iron.
Users browsing this forum: Google [Bot] and 4 guests
