In Path of Exile 2, the right currency item can completely change the outcome of your build. Among the many PoE 2 currency options, the Orb of Annulment stands out as a powerful tool. It lets you remove a random modifier from an item, giving you the chance to fix bad rolls or prepare the item for better crafting. While it may sound simple, using this currency smartly can save you hours of grinding and a lot of wasted materials.
One of the most effective ways to use an Orb of Annulment is when you have an item that’s almost perfect but has one bad mod. Instead of starting from scratch, you can try annulling that single unwanted affix. For example, imagine you’ve got a bow with three strong damage mods but one useless resistance roll. Removing that bad mod opens space for a new, more powerful craft, which could be a high-tier attack speed or elemental damage bonus.
To make the most out of this process, many experienced players combine the Orb of Annulment with other PoE 2 currency like the Exalted Orb or Orb of Alteration. A common approach is:
Start with a good base item.
Use Orbs of Alteration to roll desirable mods.
Apply the Orb of Annulment if a bad mod appears alongside good ones.
Finish with an Exalted Orb or a crafted mod to complete the item.
Another advanced trick involves influenced items. Some high-end builds require special influenced mods, and those are often expensive to roll. By using the Orb of Annulment carefully, you can protect the rare and valuable mod while removing a weaker one, giving you more control over the final outcome.
Of course, finding or farming Orbs of Annulment takes time. Many players prefer to buy PoE 2 currency to speed up their progress. If you decide to take this route, make sure you choose a trusted marketplace. Sites like U4GM provide quick, safe delivery so you can focus on crafting and playing instead of endless farming.
If you’re on a budget, farming is still a good option. High-tier maps, league mechanics like Heist or Delirium, and certain boss fights have a better chance of dropping valuable currency, including the Orb of Annulment. You can then trade extra items or currency like Chaos Orbs and Divine Orbs for the ones you need.
The key takeaway is simple: in PoE 2, currency is your crafting power. Knowing when and how to use items like the Orb of Annulment can dramatically improve your gear without wasting resources. Whether you farm or buy PoE 2 currency, having the right tools at the right time can turn a decent build into a masterpiece.
Recommended Article:Path of Exile 2 Update 0.3.0 Content Preview
Get Your Orb of Annulment from U4GM—Reset Your Gear’s Fate!
StarryDawn
Users browsing this forum: RyujiSaeki and 12 guests
