Overheated front brakes
1977 Cutly
TOA Membership Number: 1059
Years Owned: 1966 Toronados
1977 Cutlass Supreme
Postby 1977 Cutly » Thu Jun 13, 2013 6:40 pm
I thought my car was overheating at a red light, but as it turns out it was my brakes smoking. Both fronts drums were absolutely scorching.
Any advice or tips?
waterzap
TOA Membership Number: 1058
Years Owned: - 1967 Toronado
- 1978 Eldorado
Re: Overheated front brakes
Postby waterzap » Fri Jun 14, 2013 7:00 am
One of my friends had this problem with his Eldorado. Loosen the hoses from the calipers and see if any fluid comes out. His hoses were plugged up, almost nothing came out. Just had to put a new hose in. If both of yours are grabbing, could be something higher up, like an obstruction with the proportioning valve. I would start with the hoses though.
1977 Cutly
Postby 1977 Cutly » Sat Jun 15, 2013 6:00 am
waterzap wrote:I would start with the hoses though.
That really sounds like a fine idea. I can replace the brittle hoses and the old nasty fluid in one shot.
1977 Cutly
Postby 1977 Cutly » Tue Jun 25, 2013 1:18 pm
It was stuck in place today until the brakes cooled. It wouldnt go forwards or reverse.
waterzap
- 1978 Eldorado
Postby waterzap » Tue Jun 25, 2013 3:38 pm
Whole brake job is in store for you. New springs, new shoes, new hoses.
Drum brakes dont have a proportioning valve, the only other thing is the master cylinder.
bluecab
Postby bluecab » Wed Jun 26, 2013 1:11 pm
How is the pedal feel?
Were you doing stops from highway speed or just around town?
You probably know that the drum brakes were considered a weakness in the early Toro's, although a well set-up drum system should work passably. just don't expect it to be like your daily driver with 4 wheel discs that weighs 1/3 less.
1977 Cutly
Postby 1977 Cutly » Wed Jun 26, 2013 1:43 pm
They felt tight.... I was doing about fifty for fifteen miles or so. I wonder if they were dragging the whole time?
1977 Cutly
Postby 1977 Cutly » Mon Jul 01, 2013 12:52 pm
I just spoke with Kanter and discovered the reason why hey discontinued the '66 11 inch disc conversion was because of difficulties.
Back to sourcing used parts for disc brake conversions I guess
waterzap
- 1978 Eldorado
Postby waterzap » Mon Jul 01, 2013 3:04 pm
For around $300 you can probably replace the whole brake system. New or rebuilt caliper and booster. Shoes, springs, cylinders on all wheels. Might still have drums, but will work much better.
toro_mike
Contact:
Postby toro_mike » Wed Jul 03, 2013 11:31 am
1977 Cutly wrote:I just spoke with Kanter and discovered the reason why hey discontinued the '66 11 inch disc conversion was because of difficulties.
What difficulties did they speak of?
TOA #004, Webmaster
Forum Administrator
1969 W34 Toronado
