Alternator Replacement
maxsonrj
Years Owned: 1969. I am a member but do not know TOA number
Postby maxsonrj » Thu Jun 12, 2014 6:40 pm
I replaced my alternator. It seems to be charging fine but my alternator light is now on all the time. I read somewhere about older cars having an external regulator. Can there be a problem with installing a new alternator on a 1969 toro? I assume my new alternator has an internal regulator..
Postby bcroe » Thu Jun 12, 2014 7:33 pm
maxsonrj wrote:I replaced my alternator. It seems to be charging fine but my alternator light is now on all the time. I read somewhere about older cars having an external regulator. Can there be a problem with installing a new alternator on a 1969 toro? I assume my new alternator has an internal regulator..
You absolutely don't want an internally regulated alternator installed in a car
with an external regulator (like a 69). I don't even want to think of what might
happen.
On the other hand, you could convert the car by removing the mechanical
regulator and some wires. I think there is even a jumper harness to do this. Bruce Roe
Re: Alternator Replacement
Postby Otto Skorzeny » Thu Jun 12, 2014 7:44 pm
Why do you assume that your new alternator is internally regulated? Did you not purchase an alternator designed for your car?
maxsonrj
Postby maxsonrj » Fri Jun 13, 2014 7:22 pm
I meant to put a question mark at the end of that sentence. I did get one from autozone for the car. A post I saw somewhere else had me worried that new alternators had internal regulators. Looks like I need to look else where for the problem. Thanks for your comments.
1977 Cutly
TOA Membership Number: 1059
Years Owned: 1966 Toronados
1977 Cutlass Supreme
Postby 1977 Cutly » Sun Jun 15, 2014 10:44 am
does anyone still offer a rebuild kit?
Postby Otto Skorzeny » Sun Jun 15, 2014 10:50 am
From my experience you generally have to source your own parts rather than buying a one stop shop kit.
Rock Auto sells the bearings, brushes, brush holders, rectifiers, etc. but not as a complete kit.
