1988 Toronado rear brake
Bernd
Years Owned: 1975 Lancia Fulvia, 1977 APAL Buggy, 1978 BMW 633 CSI, 1988 Oldsmobile Toronado, 1991 Audi 80 Convertible, 2000 Porsche Boxster S,
Postby Bernd » Tue Sep 02, 2014 6:53 am
Hello from Germany!
I´m driving a 1988 Toronado. Everything is fine with the car except the rear brake. I installed new brake pads because I only had 100 kg breaking force. And now it´s still the same. Anybody has an idea where the problem comes from?
Thanks a lot & best regards
Bernd
Schurkey
TOA Membership Number: 67
Re: 1988 Toronado rear brake
Postby Schurkey » Thu Sep 04, 2014 5:43 pm
Failed master cylinder? Plugged rear brake hoses? Rear calipers not properly adjusted? (some rear calipers are adjusted by using the parking brake--I don't know if yours are or not.) Pinched brake tubing? Corroded valves in the anti-lock or proportioning valve?
roland
TOA Membership Number: 860
Postby roland » Tue Sep 23, 2014 11:50 pm
Hello Bernd,
If your brake problem is not fixed yet call me (germany) 08223 5298
Ruf mich an - das Problem ist die Feststellbremsenhebel an den Zangen. Wenn die richtig anliegen hast Du auch den richtigen Druck an der Fußbremse.
Roland TOA#860
Postby Otto Skorzeny » Wed Sep 24, 2014 5:27 am
Ya, what he said.
NRGF
TOA Membership Number: 40
Years Owned: 1969
Postby NRGF » Wed Sep 24, 2014 6:51 am
[quote="roland"]Hello Bernd,
Thanks to Google translate.
Call me - the problem is the parking brake lever on the calipers. When applied correctly you also have the right pressure on the foot brake.
