RTTS Pitcher Build Guide in MLB The Show 26
IronWind6
Postby IronWind6 » Tue Feb 24, 2026 7:25 pm
What is the Best Pitching Archetype for RTTS?
When starting your RTTS pitcher journey, one of the first decisions you'll make is selecting an archetype. In MLB The Show 26, pitchers are divided into different archetypes, each focusing on specific attributes. Choosing the right one can make a big difference in your development.
Here are the basic archetypes available for pitchers:
Power Pitcher: This build focuses on throwing fastballs with high velocity. It’s ideal for players who want to overpower batters with speed and heat. You’ll likely want to focus on pitches like the fastball, slider, and curveball.
Control Pitcher: This archetype maximizes accuracy and pitch placement. You’ll excel at hitting the corners of the plate, getting batters to swing and miss or hit weak contact. Great for players who enjoy pitching with precision and want to control the pace of the game.
Ground Ball Pitcher: Focuses on inducing groundouts. This build is ideal if you want to minimize fly balls and prevent home runs, especially in hitter-friendly parks.
Strikeout Pitcher: If you love blowing batters away with strikeouts, this archetype is for you. It boosts your ability to get batters to chase high fastballs or sharp breaking balls, making it easier to rack up K’s.
Two-Way Player: Though not as common, a two-way player can develop both as a pitcher and a hitter, making your player more versatile. It’s a fun option if you want to experience both sides of the game.
Most players opt for Power Pitcher or Strikeout Pitcher due to the benefit of high-speed fastballs and a better chance of getting batters out quickly.
What Stats Should You Focus On?
After picking your archetype, it’s time to focus on improving your player’s stats. In RTTS, stats play a significant role in how well you perform on the mound. Here are the most important stats for a pitcher:
Velocity: This is one of the most important stats for any pitcher, especially if you’re focusing on the Power Pitcher archetype. A high velocity means you can overpower batters, forcing them to react quickly to fast pitches.
Control: This is crucial for making sure your pitches hit the target, especially if you’re aiming for corners or throwing breaking balls. Poor control leads to walks and mistakes that hitters can capitalize on.
Stamina: A pitcher’s stamina determines how long you can last in a game before tiring out. This is key to ensuring you don’t get pulled early and can handle longer outings, especially in a season-long career.
Pitching Clutch: This stat helps with your performance in high-leverage situations, such as when you’re on the mound with runners in scoring position. A higher clutch rating means you’re more likely to succeed when the game is on the line.
Break: This stat controls how much movement your breaking pitches have. If you’re using sliders or curveballs, this stat is crucial for making those pitches more effective.
What Pitches Should You Use?
Your pitch selection is one of the most important decisions in creating your RTTS pitcher build. Here’s a breakdown of the most popular and effective pitches:
Fastball: As a Power Pitcher, your fastball should be your go-to weapon. Work on getting it up in the high 90s or even over 100 mph to challenge batters. The four-seam and two-seam fastballs are common choices, with the four-seam being the fastest.
Slider: A slider can be a devastating pitch when thrown correctly. It has sharp lateral movement and can fool batters into swinging at bad pitches. It’s a must-have for most pitcher builds.
Curveball: A great off-speed pitch that can make hitters swing early and miss. It’s also excellent for changing the batter’s timing and keeping them off balance.
Changeup: This pitch is ideal for fooling batters who are geared up for your fastball. It’s slower, with similar movement to your fastball, but it drops in speed, making it tough for batters to catch up.
Sinker: If you’re building a Ground Ball Pitcher archetype, the sinker is one of your best pitches. It induces groundouts, making it easier to avoid fly balls and home runs.
Knuckle Curve or Splitter: These pitches are excellent for deceiving batters, as they have erratic movement. If you want to add more variety to your pitch mix, try incorporating these.
How Do You Progress Your Pitcher?
Progression is where MLB The Show 26 really shines. After each game, you’ll earn points toward different attributes based on your performance. Here are a few ways to maximize your progression:
Complete Tasks and Missions: Each season comes with goals and tasks that give you bonus progression points. Completing these early can boost your development, making you a dominant pitcher faster.
Focus on Weaknesses: Look at your pitcher’s weaknesses and target those during your development. If you have low control, prioritize that early on. If you’re struggling with stamina, work on that to ensure you can go longer in games.
Upgrade Pitches: As you continue to play, you’ll unlock the ability to improve and add more pitches. Focus on improving the pitches that fit your playstyle the most.
Use MLB The Show 26 Stubs Deal: For players who want to speed up their progression, consider looking into an MLB The Show 26 stubs deal. With stubs, you can unlock better equipment and other in-game advantages that will accelerate your pitcher’s growth.
What Equipment Should You Equip?
As you progress in RTTS, you’ll unlock equipment that can further enhance your performance. Here are a few essential equipment types for pitchers:
Gloves: Look for gloves that increase your fielding ability, allowing you to make quicker plays on the mound.
Cleats: Cleats that improve your reaction speed and stamina are critical, especially when facing high-pressure situations.
Bats and Batting Gloves (For Two-Way Players): If you’re playing as a two-way player, make sure you equip yourself with quality batting gear to enhance your offensive contributions.
Training Items: These items help boost your stats directly, like increasing your pitching velocity or stamina. Equip them to stay ahead of the competition.
How Do You Excel at Pitching?
To become a dominant pitcher, it’s important to develop your skills both in-game and through practice. Here are a few tips to help you perform at your best:
Mix Up Your Pitches: Don’t throw the same pitch multiple times in a row. Change the speed and movement to keep batters off balance. It’s all about unpredictability.
Focus on the Strike Zone: Work on locating your pitches in the strike zone. Don’t just throw for speed—work on getting your pitches in tough spots to make it harder for batters to make contact.
Work the Count: Don’t be afraid to throw balls when you’re ahead in the count. Get batters to chase pitches outside the strike zone to get easier outs.
Stay Calm Under Pressure: High-leverage situations can be intense. Keep your composure and focus on executing the pitch. Remember, you’ve prepared for this.
By following these tips and working on your pitcher’s development, you’ll soon find yourself dominating in Road to the Show as a pitcher. Whether you’re focusing on strikeouts, ground balls, or simply working the corners, with the right build and practice, you’ll find success. And don’t forget, keeping an eye out for an MLB The Show 26 stubs deal can give you the edge you need to speed up your career and make your pitcher a force to be reckoned with.
