Wiring bugs and problems
followme21
- Years Owned: 66 toronado
So last fall i was having a no start issue.. Both starter/soilnoid were good. I ended up finding a purple wire from the ign switch that I spliced into and ran it out to the starter solinoid.. Boom it started I fiqured that wire was broke somewhere between the switch and the starter, so I left the wire there.. Today I had it out for the first time this year, and about 15 mins into the drive it started missing cutting out etc.. I made it home and opened the hood and noticed a wire smoking... Its kind of an cloth insulated wire (the only one like that) . I cut it before it melted.. Anyway I traced it and it eventualy splits into a black wire that goes the the + side of coil and then to the starter solenoid. The other end of it goes to the back of the fuse panel.. Appers to go to the fuses maked "olds 8131-a" as well as "trans" now thats it's cool I can wire it back together and it starts.. Im running factory breaker points. Any thoughs as what in the heck to do or check next?
followme21
Re: Wiring bugs and problems
So I poked around a bit more and discovered both of the small wires going down to the starter had gotton against the exhaust manifold and melted to it, so direct short.. Problem 1 solved. Still dealing with a relay lower left of dash that has something to do with power windows. Im getting no click and no windows.. When I bypass it the windows work. Its a 3 terminal relay, a red with white tracer, a black, and two pinks going to the same terminal. Not sure if perminatly bypassing would be a good idea or not.
That special cloth wire is the ballast resistor for your ignition coil. Normally it
limits current from the ignition circuit to the coil. But for starting ONLY, a wire
from the coil end goes down to the starter and gets connected directly to 12V.
Without the ballast in place, your points will soon burn out.
You might want to fix the big purple wire as well. Bruce Roe
Tuco
Check to see that you are getting 12v at the relay when the ignition is on. Check to make sure the ground is good at the relay. If yes to both of those then the relay is probably bad.
I personally wouldn’t leave it jumped for good.
Manage your Home Depot credit card anytime online at home depot my card login Get how to reinstall Trend Micro to install reliable antivirus protection fast. Visit Trend Micro to download and activate Trend Micro security.
Set up your Brother printer easily by following steps at install a brother printer to my computer. Download the latest brother printers driver for windows 11 for smooth printing. Update brother printers driver for windows 11 to fix errors and boost performance. Install brother printers driver for windows 11 easily for any model or device. Keep your printer running strong with updated brother printers driver for windows 11.
syw.accountonline.com pay bill lets you track your card activity. Manage payments anytime via syw.accountonline.com pay bill. Securely view your SYW account using syw.accountonline.com pay bill.
Activate your new Discover card quickly and securely at activate your Discover Card. Activate your UnitedHealthcare card easily at activate uhc com card activation. Visit activate uhc com card activation to turn on your new UHC plan card.
Set up your Vizio TV quickly by following the steps at VIZIO com setup enter code. Visit VIZIO com setup enter code to connect your Vizio device and start streaming.
Access your business finances easily with QuickBooks download login. Use QuickBooks download to manage invoices and expenses fast. Sign in through QuickBooks download to track your accounts. QuickBooks download gives secure access to all your data.
Users browsing this forum: Google [Bot] and 5 guests
