Drum Brakes '69 Toronado
NicolasB
Postby NicolasB » Tue Jun 30, 2020 10:56 am
Does anyone know if the rear drum brakes on a 1969 Toronado are self-adjusting? I just want to make sure before I replace them with the new shoes I bought.
Re: Drum Brakes '69 Toronado
Postby Otto Skorzeny » Wed Jul 01, 2020 5:52 am
'66 is so I'd expect '69 to be the same.
NicolasB
Postby NicolasB » Wed Jul 01, 2020 8:26 am
Okay great, thanks!
Postby Otto Skorzeny » Wed Jul 01, 2020 1:19 pm
I forgot to mention that you still have to adjust the brakes after you install the new shoes. Follow the instructions in the FSM but basically they're the same as any other common drum brake system.
Do one side at a time so you can use the other side as a reference for installation of the parts on the other side.
Don't get your star wheel adjusters mixed up.
The left side adjusters have right hand threads.
The right side adjusters have left hand threads.
A friend of mine had the wrong adjuster on one of the front drums of his 1960 Cadillac and the brake constantly adjusted itself while driving so that it would lock up, overheat, and smoke.
Sonny Kennedy
Postby Sonny Kennedy » Thu Aug 13, 2020 12:38 am
"I forgot to mention that you still have to adjust the brakes after you install the new shoes. Follow the instructions in the FSM but basically they're the same as any other common drum brake system."
Thanks for the tip, man! I'll be keeping that in mind.
Postby xeror » Tue Jul 22, 2025 11:01 pm
Postby xeror » Tue Jul 22, 2025 11:02 pm
Postby xeror » Tue Jul 22, 2025 11:03 pm
