1969 toronado project
cartercarbaficionado
Years Owned: 1969 oldsmobile toronado (El basketcase)
Postby cartercarbaficionado » Wed Sep 11, 2024 12:07 am
finally getting back to this car after a year of sitting.
I forgot how extremely solid it is underneath for 30k miles of dirt roads.
anyways I haven't been able to pull my blown up olds 455 since I haven't found a replacement or really any parts to finish the ac or accessory drive. plus the interior is messed up still.
I'm currently torn on whether or not to keep this front wheel drive or make a trans tunnel and cut out the spare tire well to make this a rear wheel drive. I would perfer all wheel drive so I can actually drive it year round but that's turned out to be quite the debacle
let me know if anyone has parts or a good engine near Washington state
Slick66
Re: 1969 toronado project
Postby Slick66 » Fri Sep 13, 2024 7:47 am
Hey I'm just curious on what your theory would be on all wheel drive. There's no way to work a transfer case into the drivetrain. On rear wheel drive, wouldn't it just be easier to buy a Riviera and swap the body over. Of course you would need to alow for the drive train.
Postby cartercarbaficionado » Sat Sep 14, 2024 4:18 am
believe it or not there is. I just don't want to swap those motors in since it's mostly v6 stuff, the way to do it easily would be to use a 6t80e(or 4t65eHD) with the differential and output cup with the awd output box from a pontiac Aztec and then using a 4.9 Cadillac motor just like a fiero would (currently making plans to awd one of those for a rally car) I could also use a transfer case from a chevy astro van and cut up the floor a bit to make It fit.
also yeah no. a riveria around Oregon is quite expensive (over 10k)for one that's even half as nice as this $1500 toronado
luckily the toronado uses a quad shock leaf spring beam axle so swapping in a 70s square body rear axle is easy and let's me keep the stock wheels and oversized drums which will be a plus when I decide to later attempt to shove abs in this. it's a little difficult but it's primarily using a 93 and up gm 3 abs unit that can just be ran through a 1998 Monte carlo ecm for the wheel speed and intensity
honestly though the rwd is gonna be the easiest part of this particular toronado since it has just about every wiring issue it could have had from the previous owner pulling it out of a barn and promptly almost burning it to the ground with a chevy 1 wire alternator he wired the power to ground with.
Lipient
TOA Membership Number: 127
how long before sex should i take dapoxetine
Postby Lipient » Wed Nov 13, 2024 9:06 pm
59 61 Bisphosphonates are a class of drugs that bind bone minerals where they are absorbed by mature osteoclasts; this results in osteoclast apoptosis and suppression of bone resorption <a href=https://fastpriligy.top/>where can i buy priligy online safely</a>
will
Postby will » Thu Dec 11, 2025 1:37 am
The Activate.uhc.com site simplifies the process of registering and verifying your UnitedHealthcare member ID.
Activate.uhc.com provides a quick way for new UHC members to set up and confirm their health plan access.
Use Activate.uhc.com to activate your UnitedHealthcare card and start using your benefits right away.
Activate.uhc.com helps members complete their UHC card activation in just a few guided steps.
The portal at Activate.uhc.com lets you verify your identity and unlock your UnitedHealthcare online account.
will
Postby will » Thu Dec 11, 2025 1:39 am
Without these drivers, your Brother Printer drivers may not print or connect properly.
Brother Printer drivers keep your printer up-to-date with modern operating systems.
Brother Printer drivers provide necessary tools for troubleshooting and printer maintenance.
Brother Printer drivers ensure printed documents match original formatting and colors.
Installing online Brother Printer drivers enhances performance and prevents errors.
will
Postby will » Thu Dec 11, 2025 1:41 am
The Brother Printer drivers make it easy to customize print quality, size, and paper type.
Brother Printer drivers ensure reliable wireless printing from phones, tablets, and PCs.
Brother Printer drivers support your Brother printer’s full capabilities for home and office use.
will
Postby will » Thu Dec 11, 2025 1:45 am
Trend micro download lets you easily activate your Trend Micro security subscription online.
Use Trend micro download to enter your product key and enable full protection on your device.
Activate your Trend Micro antivirus software by visiting Trend micro download and following the setup steps.
Trend micro download is the online page to validate your license and start using Trend Micro security tools.
Get complete device protection by entering your activation code at Trend micro download.
will
Postby will » Thu Dec 11, 2025 1:46 am
Trend micro download helps users activate and verify their Trend Micro product before installation.
Visit Trend micro download to unlock premium antivirus features with your product key.
Quickly set up and activate your Trend Micro security service with the help of Trend micro download.
Access Trend micro download to authenticate your Trend Micro product and begin installation.
will
Postby will » Thu Dec 11, 2025 1:50 am
activate.uhc.com is the online portal used to securely register and activate UnitedHealthcare insurance cards.
With activate.uhc.com, users can quickly verify their insurance coverage and start using their benefits.
The activate.uhc.com website helps members create an account and complete the activation process for their health plan.
activate.uhc.com allows individuals to connect their insurance details online and begin accessing UnitedHealthcare services.
The platform at activate.uhc.com guides users step-by-step through activating their UHC medical membership.
