Transmission dipstick
Kendicott1
Years Owned: Would like to aquire 1966,'67 or '68.
Postby Kendicott1 » Wed Oct 04, 2023 5:20 pm
Do the '66 & '67 Toros have different transmission dipsticks? If so- why is that? I have a '66 & the dipstick is straight & flat. The finger puller snapped off so i got one for a '67 thinking their engines/ trans were indetical. The dipstick i rcv'd was about an inch longer, it was wider & it had twists in it also.
Re: Transmission dipstick
Postby Otto Skorzeny » Mon Oct 09, 2023 7:16 am
From the bottom of the washer to the tip, are they the same length? Is the full mark in the same position relative to the bottom of the stop washer?
66tomato
Years Owned: Just bought a 66
Postby 66tomato » Sun Oct 22, 2023 12:52 pm
Can someone with a 66 and correct dipstick measure theirs? The dipstick on mine is very fussy and doesn't seem to go down all the way.
Kendicott1
Postby Kendicott1 » Thu Aug 15, 2024 1:55 pm
Otto Skorzeny wrote:From the bottom of the washer to the tip, are they the same length? Is the full mark in the same position relative to the bottom of the stop washer?
Back with another head scratcher. I found another trans dipstick, exact same as last one, the problem is, while checking the fluid level - car on flat surface,engine warm & running in neutral- one side of the dipstick it shows the trans fluid quart low, i look at the other side
of the dipstick, its showing way too much fluid, aprox 2" above the full mark!! What gives??
Users browsing this forum: armandoben and 10 guests
