Hey all, I just wanted to share something I found. When I put my engine in, I didn't like how I had to run the upper heater hose connection from the heater pipe on the side of the engine. I had to make a loop behind the engine in order to not kink the hose because of the sharp angles. I found a Gates part number that works well for this. It's almost a drop-in replacement; it was maybe a half inch to an inch short, but it was able to be easily attached with only a little bit of tension in it.
Gates p/n 19747, listed for a 1998-2003 Chevrolet S10/GMC Sonoma w/ 4 cylinder engine.
Hopefully this helps somebody clean up their engine compartment without resorting to NOS hoses! A cut length of straight hose worked well enough between the heater control valve and lower heater core port. It takes a little bit of twisting/positioning to make sure it doesn't kink, but works well!
Please note, zip ties around plug wires were temporary during transport of engine, don't knock on 'em lol
Heater Hose
KaydenST
- Years Owned: Own a 1966 Toronado
Heater Hose
- heater hose.jpg (337.87 KiB) Viewed 2207 times
