Vacuum check valve
68 Toro
TOA Membership Number: 99
Years Owned: 1968
Vacuum check valve
Postby 68 Toro » Fri Jan 18, 2013 5:24 pm
Hi,
Does anbody know who sells new vacuum check valves? This valve is inserted on the vacuum line that comes off the large vacuum reservoir.
Thank you,
Dave B.
Miami, FL
TOA # 99
68 Toro
Years Owned: 1968
Re: Vacuum check valve
Postby 68 Toro » Fri Jan 18, 2013 8:36 pm
The vacuum check valve can be seen in the center of this image:
http://www.toronado.org/FAQ/GenI/68vactub.htm
Dave B.
Miami, FL
TOA # 99
Chazzer
TOA Membership Number: 146
Postby Chazzer » Sat Jan 19, 2013 7:57 am
Hey David,
Someone probably has an NOS one somewhere. It’s trying to find out who and where. I’m sure you will have an easier time tracking down a used one. The same could be said concerning the rear blower.
Cheers, Jim
TOA# 146
