In Elden Ring, success against bosses often hinges on more than just stats and raw skill. Knowing how to effectively use certain Elden Ring items before a fight can make the difference between a hard-fought victory and a frustrating death loop. Whether you’re trying to preserve your Elden Ring Runes or simply survive the encounter, these 23 items offer critical advantages when properly timed and combined.
Here’s a breakdown of how to use them to maximize your boss-fighting potential.
1. Flask of Wondrous Physick
Mixing the right combination of Crystal Tears can grant buffs like temporary infinite stamina or damage negation. Prep this in advance to match the nature of the boss.
2. Blessing of the Erdtree
This powerful incantation provides a substantial healing-over-time effect, which is great to cast just before entering a fog gate.
3. Boiled Crab / Boiled Prawn
Simple but effective—these consumables grant a temporary boost to physical damage negation. They’re perfect for tanking heavy melee bosses.
4. Exalted Flesh
Boosts physical attack power for a limited time. Use right before combat begins for an offensive edge.
5. Fire Grease / Magic Grease / Holy Grease
Coat your weapon with elemental damage to exploit a boss's weakness. Keep a stock of different greases for elemental flexibility.
6. Roped Pots
These thrown items (like Roped Fire Pot or Roped Holy Pot) are ideal for initiating a boss fight with burst damage. They explode behind you, allowing for a quick disengage.
7. Sleep Pot
Some bosses, like certain humanoid enemies, are susceptible to sleep. Use these to create openings or skip early phases.
8. Throwing Daggers
While not a high-damage option, they’re useful for pulling bosses from range or interrupting wind-up animations.
9. Silver-Pickled Fowl Foot
This item boosts rune acquisition. Use it when you’re confident you’ll win the fight—especially valuable in farming Elden Ring Runes from repeatable boss encounters.
10. Golden Vow
Cast this incantation before combat for an all-around buff to attack and defense. It’s a staple in PvE prep routines.
11. Flame, Grant Me Strength
Stacks with Golden Vow and offers a big damage boost, especially useful for strength or fire-based builds.
12. Starlight Shards
Use to recover FP slowly over time—handy if you’re a caster heading into a long fight and want to conserve flasks.
13. Talisman Pouches
Equip different talismans based on the boss. For example, Radagon’s Scarseal for STR fights or Dragoncrest Shield Talisman for tanking.
14. Rune Arc
If you’ve activated a Great Rune, a Rune Arc can empower it, offering major stat boosts. Always use one before difficult bosses.
15. Uplifting Aromatic
A Perfume item that grants a protective shield—use right before or during a phase shift in battle.
16. Ironjar Aromatic
Makes your character incredibly tough but slow. Use it for tanking high-damage hits or holding aggro in co-op.
17. Bewitching Branch
Can charm some humanoid enemies during multi-phase boss fights. Situational, but useful for turning the tide briefly.
18. Soft Cotton
Reduces fall damage and noise. Surprisingly helpful in fights with vertical movement or sneaky approaches.
19. Neutralizing Boluses
These and other ailment-cure items (like Preserving or Thawfrost Boluses) are essential when a boss inflicts status effects.
20. Spirit Ashes
Not technically a consumable item, but vital nonetheless. Summon the right Ash to complement your build—tanky ashes like Lhutel or DPS ones like Black Knife Tiche.
21. Crimsonburst Crystal Tear
Mix this in your Flask to gain passive HP regen—especially useful in prolonged or multi-phase fights.
22. Opaline Bubbletear
Negates one instance of damage, including fatal hits. Ideal for risky boss fights or opening gambits.
23. Lantern
Equip it for visibility during dark encounters. No stamina drain, and it lets you keep a shield or two-handed weapon ready.
Bosses in Elden Ring test every aspect of your build—from gear choices to situational awareness. Smart use of Elden Ring items not only improves your odds of survival but also enhances the strategic depth of each encounter. And since Elden Ring Runes are always at risk, every bit of preparation pays off.
Before stepping through that fog gate, ask yourself: Did you use everything at your disposal?
Sometimes, the right item is all it takes to turn a boss fight from punishing to poetic.
How to Use 23 Elden Ring Items for Boss Preparation
CryptCoder
Users browsing this forum: Palmaarins and 14 guests
