hi guys,
the last things i need to get my toro back on the street are the upper bolts for the rear horizontal shocks. u can see them in the picture....can someone tell me the size of these babies?
thx and bye
Bolts for horizontal shocks / Size / Toro 1970
- Eightballz
- TOA Membership Number: 826
- d6352fc35d.jpg (48.98 KiB) Viewed 18632 times
Re: Bolts for horizontal shocks / Size / Toro 1970
Well, I haven't gotten around to that just yet... I should be putting on new Edelbrock shocks on my '66 before the end of the month. So if you don't get an answer before then, I'll check when I pull it out.
Eightballz wrote:hi guys,
thx and bye
What is the issue?
The bolt goes all the way through the frame with nut on the other side, its not something you'll get off the shelf.
- Eightballz
hi,
the issue is that i'm from germany...we have the metric system, so its nearly impossible to go to the next car-shop and get the right bolts. i need to order them at a special mailorder here in germany...for those guys i need the size and thread pitch. my car came without the bolts.
@ twilight: that would be sooo cool
Eightballz wrote:hi,
R i g h t . . . . They are grade 5, 1/2 inch (.500 mm) diameter, 7-7/8 inches (175.0 mm) over all length, thread length 1-1/2 inches (40.0 mm) with 13 threads per inch -- bolt head size 3/4 inch (19 mm)
forsee link / chart for 1/2 - 13
http://www.portlandbolt.com/technicalin ... pitch.html
Nut grade C /8 prevailing torque lock USS course thread nut with one flat washer at nut end. This should help to get a cost to make them.
as it is I have a set that i may be able to provide, depending on what you find in the way of cost to have them made.
Good luck
- Eightballz
oh bill..ur my hero...thx for that :
- TOA Membership Number: 38
- Years Owned: 1970 multiple
thx and bye
Hey Eight, are those composite leaf springs? I'm trying to get a guy here to make a run of some correct steel tapered mono-leafs but we haven't come to terms yet! How do you like those you have?
- Eightballz
hi,
that pic is not mine...found it under http://www.toronado.de ..just took it to show the bolts i needed. as far as i know..the owner just painted the original spring leafs
bye
bye
1970w34 wrote:Eightballz wrote:hi guys,
thx and bye
Kanter sells leaf springs for 1st Gen's.... I'm not sure if they're mono, but they are steel tapered.
http://www.kanter.com///productdetail.a ... 20&Prc=125
Twilight Fenrir wrote:1970w34 wrote:Eightballz wrote:hi guys,
thx and bye
Yeah, I bought the same set from Eaton--they are multi-leaf. I'm kinda picky about that sort of thing and want to get some repro springs one of these days when I can convince someone to do a run.
