Bolts for horizontal shocks / Size / Toro 1970
Eightballz
TOA Membership Number: 826
Postby Eightballz » Sat May 07, 2011 2:22 am
hi guys,
the last things i need to get my toro back on the street are the upper bolts for the rear horizontal shocks. u can see them in the picture....can someone tell me the size of these babies?
thx and bye
TOA Membership Number: 839
Re: Bolts for horizontal shocks / Size / Toro 1970
Postby Twilight Fenrir » Sat May 07, 2011 8:04 am
Well, I haven't gotten around to that just yet... I should be putting on new Edelbrock shocks on my '66 before the end of the month. So if you don't get an answer before then, I'll check when I pull it out.
69W34
Postby 69W34 » Sat May 07, 2011 8:28 am
Eightballz wrote:hi guys,
thx and bye
What is the issue?
The bolt goes all the way through the frame with nut on the other side, its not something you'll get off the shelf.
Eightballz
Postby Eightballz » Sat May 07, 2011 9:39 am
hi,
the issue is that i'm from germany...we have the metric system, so its nearly impossible to go to the next car-shop and get the right bolts. i need to order them at a special mailorder here in germany...for those guys i need the size and thread pitch. my car came without the bolts.
@ twilight: that would be sooo cool ;)
69W34
Postby 69W34 » Sat May 07, 2011 11:39 am
Eightballz wrote:hi,
R i g h t . . . . They are grade 5, 1/2 inch (.500 mm) diameter, 7-7/8 inches (175.0 mm) over all length, thread length 1-1/2 inches (40.0 mm) with 13 threads per inch -- bolt head size 3/4 inch (19 mm)
forsee link / chart for 1/2 - 13
http://www.portlandbolt.com/technicalin ... pitch.html
Nut grade C /8 prevailing torque lock USS course thread nut with one flat washer at nut end. This should help to get a cost to make them.
as it is I have a set that i may be able to provide, depending on what you find in the way of cost to have them made.
Good luck
Eightballz
Postby Eightballz » Sat May 07, 2011 12:44 pm
oh bill..ur my hero...thx for that : :)
1970w34
TOA Membership Number: 38
Years Owned: 1970 multiple
Postby 1970w34 » Sun May 22, 2011 10:51 am
thx and bye
Hey Eight, are those composite leaf springs? I'm trying to get a guy here to make a run of some correct steel tapered mono-leafs but we haven't come to terms yet! How do you like those you have?
Eightballz
Postby Eightballz » Sun May 29, 2011 5:30 am
hi,
that pic is not mine...found it under http://www.toronado.de ..just took it to show the bolts i needed. as far as i know..the owner just painted the original spring leafs
bye
Postby Twilight Fenrir » Sun May 29, 2011 6:50 am
thx and bye
Kanter sells leaf springs for 1st Gen's.... I'm not sure if they're mono, but they are steel tapered.
http://www.kanter.com///productdetail.a ... 20&Prc=125
1970w34
Postby 1970w34 » Mon May 30, 2011 12:40 pm
thx and bye
Yeah, I bought the same set from Eaton--they are multi-leaf. I'm kinda picky about that sort of thing and want to get some repro springs one of these days when I can convince someone to do a run.
Users browsing this forum: Google Adsense [Bot] and 25 guests
