1966 Toro headlights trouble
- harascho
Re: 1966 Toro headlights trouble
And now the solution:
- Switch_mod_s.jpg (207.97 KiB) Viewed 11019 times
- harascho
The drawback is the lamps will close slowly because VAC is bled through the headlampswitch and there is a little longer hose than in the version with that special T-checkvalve -piece..
Harald
Harald
MikeB
- Years Owned: 1966
The switch vacuum only raises the lights (when on) and unlocks the lights (when off). The check valve in the tee closes with the vacuum to open the lights, and the check valve opens when the vacuum disappears to allow it to bleed the canisters and close.
Adding a regular tee inline with the canisters and putting a one way valve on it worked for me, after I found the line pinched behind the battery.
Mike.
Mike.
MikeB
- Years Owned: 1966
I used one of these.
http://www.summitracing.com/parts/rnb-4 ... fgodc0YAoQ
Better than drilling into a rare switch.
Mike.
Mike.
cialis company information
<a href=https://cialis.lat/discover-the-best-prices-for-cialis>buy cialis 5mg</a> B BrdU positive cells for both transgenic and WT mice counted and expressed as a ratio of positive nuclei to the total number of nuclei counted percentage
priligy senegal
<a href=https://fastpriligy.top/>priligy tablets</a> clavulanate vibramycin doxycycline Although equities rose on Tuesday on hopes the first partialshutdown of the U
