Winter upgrades on the list...
68 Toro
TOA Membership Number: 99
Years Owned: 1968
Re: Winter upgrades on the list...
Postby 68 Toro » Mon Oct 31, 2011 3:11 pm
As you can see, over the years I have given this a great deal of thought. My factory bench seat is in perfect condition. However it becomes uncomfortable during drives greater than 25 miles or so, and I have no problem modifying my car in a "blasphemous" fashion. Witness the front disc brakes, aftermarket wheels, computer chip-controlled dual electric fans, etc. Modernizing this revolutionary design to current standards of safety, comfort and reliability, is my overall goal.
In addition to FORWARD modifications, I have one REARWARD modification still to be done. A few years ago I purchased a 1966 Toronado steering wheel that was in near-perfect condition. Subsequently I sent it out to have the plastic reconditioned (there was one small crack). My goal is to somehow mount it on a 1968 tilt-telescopic steering column. This endeavor may involve the fabrication of a custom adapter plate, and the horn wiring interface mismatch has to be solved as well. No steering wheel in history has equalled the design of the 1966 Toronado's, except, perhaps, for the single-spoke Citroen?
Dave B.
Miami, FL
TOA # 99
Stubbe
TOA Membership Number: 173
Postby Stubbe » Sun Nov 06, 2011 7:23 am
after trying many aftermarket mounts I made one out of sheet metal and made it line up with the original panal screws good clearence and easy to reach and I wrapped it with vinyl left over from re-doing the interior
Mike AKA Stubbe
TOA 173
1966 Deluxe
xgecko
TOA Membership Number: 831
Postby xgecko » Sun Nov 06, 2011 8:51 am
I have a tach temporarily mounted there from the previous owner. I don't particularly like that location as it is a bit dangerous in a crash - which of course I hope never happens but...
I am lucky in that my parts car has the radio in the Instrument Panel and so this winter I plan to swap panels so I can install my Kenwood head unit directly in the hacked up IP.
68 Toro
Years Owned: 1968
Postby 68 Toro » Sun Nov 06, 2011 7:15 pm
I would like to see your modified instrument panel. I'm looking for ideas. Installing just the head unit into the factory radio position is an intriguing solution. However I've gotten used to my future plan of installing a custom floor console for a large (double-DIN) DVD player/GPS navigator, plus cupholders, sunglasses holder, change drawer, etc.
Dave B.
Miami, FL
TOA # 99
xgecko
Postby xgecko » Mon Nov 07, 2011 8:56 am
I have not yet removed it from the donor car but it looks like they just hacked it to allow a modern 1-DIN unit to be installed.
Hmm... just realized that the IP in the donor car, being a 68, has the ignition on the IP. Not sure what to make of that.
I am planning to build a fibeglass console at some point and had considered mounting the stereo in that. I'll have to see once I start digging into that aspect of the build.
68 Toro
Years Owned: 1968
Postby 68 Toro » Mon Nov 07, 2011 5:54 pm
On my 1968 Toronado, the ignition key is on the instrument panel.
Note: this photo taken before I removed the dead dashboard clock and installed an engine temperature gauge in its hole.
DB-Dashboard - 7.JPG (202.91 KiB) Viewed 13396 times
Dave B.
Miami, FL
TOA # 99
xgecko
Postby xgecko » Mon Nov 07, 2011 6:03 pm
Yes, that is the issue. My 69 has it on the steering column. Not sure what to think at this point but it probably does not matter much; I can find some way to deal with it.
68 Toro
Years Owned: 1968
Postby 68 Toro » Mon Nov 07, 2011 7:47 pm
Remove the ignition switch and install a 2nd power outlet. The power outlet need not be used for anything, but it might appear better than an ignition switch.
Dave B.
Miami, FL
TOA # 99
xgecko
Postby xgecko » Tue Nov 08, 2011 6:36 am
That is actually one of the things I was considering. I can always use more power outlets...
68 Toro
Years Owned: 1968
Postby 68 Toro » Tue Nov 08, 2011 5:22 pm
I put a dolphin light into my power outlet. Here in Miami, these things are necessary.
Note the engine temperature gauge in the place previously occupied by the dead dash clock.
Toro DashTemp2.jpg (162.82 KiB) Viewed 13394 times
Dave B.
Miami, FL
TOA # 99
