425 & 455 crankshaft
edj2001
TOA Membership Number: 1075
Postby edj2001 » Fri Oct 18, 2013 9:30 pm
Does anyone know if the crank casting # changed between the 425 and the 455? I have two cranks with casting number 384722 and I want to make sure they are both 425 cranks.
Remind me also, the main bearing OD on the both cranks (425 & 455) is 3.000 and the rod bearing crank OD is 2.500, Correct? Stroke increased from 4 inches to 4.25 inches, bore stayed same?
BTW, I have been posting large Toro items on EBay too big to ship so come to Dallas next weekend and pick these up. I have been taking these out of storage, they have been stored since 1985. I will buy you lunch.
Here are some links so far. I will be putting the cranks up as soon as I know which engine.
http://www.ebay.com/itm/161130664979?it ... m=&vxp=mtr
http://www.ebay.com/itm/161130369550?ss ... 1423.l2649
http://www.ebay.com/itm/161130715392?ss ... 1555.l2649
http://www.ebay.com/itm/161130739739?ss ... 1555.l2649
Gene Johnson
69W34
Re: 425 & 455 crankshaft
Postby 69W34 » Sat Oct 19, 2013 10:27 pm
384722 would ID a 425* crank which is forged and will have a large parting line, the 455 is cast and will have a 3/4" to 1" tall N on one of the throws ( if memory servers think the front) signifying Nodular and have a small but well defined parting line.
* the same crank was used on the 400 as well.
Schurkey
TOA Membership Number: 67
Postby Schurkey » Sun Nov 24, 2013 4:10 pm
455 cranks can be forged (rumor says first month of 455 production) or cast (everything except the first month of 455 production) There's a forged crank in the 455 currently installed in my Toro.
The cast cranks can have a large "N" (supposedly for "Nodular"), a smaller "cn" (supposedly for "Cast Nodular"), or no letter marking at all. Some folks prefer the "large N" cranks because once upon a time they were believed to be stronger than the others. I'm not sure that strength difference actually exists.
69W34
Postby 69W34 » Sun Nov 24, 2013 5:48 pm
I agree that forged 455 cranks are out there ... BUT... the timing and total volume is suspect hence they are few and far between and no reason to muddy the water with 425 forged cranks.
Now I add the following: it cost money to make the forging dies to make a crank ... but ... it takes longer to cast, cool and season a block, crank or heads before machining. So question is what was the driving force? ......... a late or delayed start of the casting processes for the 455 cranks or a last minute decision to move from forged to cast or was it some other extenuating situation that resulted in the over lap?
Schurkey
Postby Schurkey » Fri Dec 20, 2013 9:34 am
My understanding is that GM closed the plant that produced the forged crankshafts for Olds (and perhaps others???) in '67 or early '68. The '68 Olds small-blocks also got cast cranks instead of forged.
A cast crankshaft is cheaper than a forged crank. In grocery-getter and mild-to-moderate performance use, a cast crank is "good enough".
faarigia
Postby faarigia » Thu Feb 19, 2015 12:47 am
Check with the guys at Cinnabar Engineering in Sandusky Michigan--GMC Motorhome specialists and always very helpful.
I'd bet they can help you get the correct seals.
You can check out our latest Pass4sure a+ and written by our free ccna 100-101 workbook to help you pass passguide.You can also purchase www.stevenson.edu Our Florida Southern College is simply excellent in quality.
Postby Otto Skorzeny » Thu Feb 19, 2015 6:27 am
They could probably help, but the original post is over a year old. Hopefully everyone got their crankshaft issues sorted out already.
Sleenda
TOA Membership Number: 774
cialis cheap europe
Postby Sleenda » Wed Jul 03, 2024 8:47 am
She might also look for signs of infection with another instrument <a href=https://cialis.lat/discover-the-best-prices-for-cialis>cheap cialis</a> Whyte J, et al
DoodoVage
TOA Membership Number: 612
priligy 30mg price australia
Postby DoodoVage » Mon Sep 02, 2024 1:16 am
<a href=https://enhanceyourlife.mom/>can you buy priligy online</a> 2006 Nov; 27 11 877 85
biowsVab
TOA Membership Number: 936
Say yes to budget-friendly solutions - click for the cheapest medications online
Postby biowsVab » Tue Oct 01, 2024 12:24 am
Click the link below to buy medications online >>> https://leonpills.shop
Your satisfaction is guaranteed; we take pride in our customer satisfaction. Get fast, guaranteed results for optimal health.
