66 Toro dash turn signal light
I had to remove my instrument cluster to fix some wiring issues. As long as I have it out I am going to replace all the bulbs and give it a good clean up. The green lens or "filter" needs to be replaced for the turn signal indicators. Any tips on where to get something that will work? Thanks, Mark
Re: 66 Toro dash turn signal light
I'm debating on new guages or fix. I need to know what bulb number you used. Any info gleened from your expierence would be appreciated.
MNfirefighter
- TOA Membership Number: 1
I've heard of people using just pieces of color plastic that they trim down to fit. Some people have used the little plastic tabs for file folders and items like that. It seems that the plastic dash covers that give those lights their color are not available as replacement parts so people have just made their own. That is a "to do" for my toro so maybe someone else can chime in
