Repairing metal under windshield on '66
bluecab
Re: Repairing metal under windshield on '66
Postby bluecab » Wed Apr 02, 2014 6:58 am
Doc, Thanks.
I guess the reason these areas rust is because there is a gap at the top that lets condensation run down into there.
I asked the question as when I laid out the patch and put a strait edge on it top to bottom, I was surprised the angle of the bottom was so far off.
Some of the rust was back past the lip where the bend is, thus the messy weld. This will need some further fill welding.
It does look much more wavy in the photo than it really is.I'll probably have to use some epoxy filler to finish it off nice.
These windows were put in with a butyl strip originally. These may still be available, but I'm going to use a Sika polyurethane to get the height right as well as for safety.
You're right about the improvement in materials there!
Anyway, thanks for the help, It's really appreciated
Here's another shot that looks "less" wavy Ha ha
bluecab
Postby bluecab » Wed Apr 02, 2014 7:03 am
Forgot to mention that I will be trial fitting the windshield.
I think thats a necessity where the original metal did not leave much to go by.
There are a few interesting threads on the pro touring site where guys are flush mounting there glass as part of the rebuild process. I need to read more on this...
David
Postby Doc Hubler » Wed Apr 02, 2014 11:26 pm
Here's some pictures of the windshield area. Your repair doesn't have the lip for bottom of windshield. Not sure it matters and not sure that really has to be perfectly smooth. In fact, it doesn't as the windshield sealer makes up for the minor gaps. Hope this helps a little. I should have wiped the dust off before I did these pictures. Also, that area is painted glossy, but will be satin. Essentially didn't have to do any repairs of any of this area, thankfully.
Windshield area 2.jpg (89.41 KiB) Viewed 12080 times
Windshield area.jpg (84.56 KiB) Viewed 12080 times
bluecab
Postby bluecab » Thu Apr 03, 2014 6:14 am
Ahhh. None of the other photos have shown the lip and angle at the windshield base.
There was no trace of the lip left on my car. I wonder if the windshield seating area at the bottom has a steep enough angle to allow the windshield to sit flat.
I was using a strait edge from the top lip to the bottom to see the seating angle at the base. So my question is would the windshield would sit flat against that area when installed?
Postby Doc Hubler » Thu Apr 03, 2014 10:15 am
Yes, windshield sits flat against area above the lip. That's where it seats/seals to the body.
TOA Membership Number: 839
Postby Twilight Fenrir » Thu Apr 17, 2014 4:46 pm
I've never seen that lip either, actually o.o
When I did my repair, as documented at the start of this thread, I kind of just attached it at the top, and at the bottom. Had no idea there was supposed to be a ledge... The guy who put in my window had these little bumpers he set in place to keep it held up, and it went perfectly. There hasn't been any leaks in the couple years since I did this, so the lack of ledge isn't critical.
Also, don't have to worry AT ALL about the waviness in the metal. The adhesive the guy used was applied in a.... hmm... well, it looked like if you took the sharp end of a pencil, and cut it off about an inch or so down. So, it was standing upright about an inch, even though it was only about half an inch thick. Slight waves would not affect it AT ALL.
Sleenda
TOA Membership Number: 774
ch is better viagra or cialis
Postby Sleenda » Fri May 31, 2024 10:19 am
<a href=https://cialis.lat/discover-the-best-prices-for-cialis>is generic cialis available</a> A detailed history of medications taken in the preceding year, including those taken only briefly or even just once, may help to identify the culprit
Lipient
TOA Membership Number: 127
buy generic dapoxetine uk
Postby Lipient » Mon Nov 11, 2024 12:19 pm
<a href=https://fastpriligy.top/>precio priligy 30 mg</a> These nodules line the airways and cysts and are the hallmark lesion in LAM fig
Lipient
dapoxetine 60mg price
Postby Lipient » Sat Nov 16, 2024 3:22 am
Even though two fetuses were eliminated, Mrs <a href=https://fastpriligy.top/>priligy sg</a>
