Bruce, what is your site? I went to your profile but didnt see anything.
Alex
Newbie question-- 1966 grinding noise on reverse attempt
Re: Newbie question-- 1966 grinding noise on reverse attempt
Checkov wrote:Bruce, what is your site? I went to your profile but
didnt see anything. Alex
You can see all sorts of odd stuff on my PHOTOBUCKET site. There
are 2 ALBUMS about TH400/425 transmissions: SWITCH PITCH
TRANSMISSIONS, and BUILD A SWITCH PITCH TRANSMISSION. SPT
about 6th picture shows some piston seals I found, which are coming
apart (ready to lose clutch pressure, burn up the clutch pack, and
fill the whole trans with poison). They are really worse than you can
see in the picture. If you saw all the bad rubber I see, you would
make sure it gets renewed.
http://s93.photobucket.com/albums/l71/bcroe/
(that is a lower case "L"71, not an upper case "i"71)
click on a Sub-Album
click on a picture to enlarge + description
BRUCE ROE
5719 EAST SKINNER ROAD,
STILLMAN VLY, IL 61084-9215
Phone 815 234-8039
