1966 Toronado Parts Car
bomberman89
TOA Membership Number: 1
Years Owned: 1969 oldsmobile toronado
Re: 1966 Toronado Parts Car
Postby bomberman89 » Wed Apr 08, 2015 9:59 pm
Hello do you still have the parts car?
If so i am looking for both the hood hinges please, and if you are willing to ship to california thank you.
Let me know please
Tomasz
Postby Tomasz » Sat May 23, 2015 7:42 am
Need Steering Linkage Shock Absorber
Do You have it??
Postby Otto Skorzeny » Sat May 23, 2015 9:42 am
The steering damper is available new from Rock Auto and most likely any other auto parts chain store you'd care to visit.
majordan
Years Owned: 1966 Toronado(2), 1941 Pontiac Silverstreak; 1954 Pontiac Wagon, 1947 Pontiac Silverstreak, 1962 Cadillac Coupe deVille, 1996 Buick Roadmaster Wagon(2), 1976 Lincoln Coupe, 1960 Buick Invicta.
Postby majordan » Tue Aug 11, 2015 8:32 pm
:?: Do you have the vacuum cannisters for the headlights???? :?:
lew
Postby lew » Wed Aug 12, 2015 7:16 am
don't have the vacuum actuators, they went to Connecticut.
Freddy67
Postby Freddy67 » Wed Nov 11, 2015 10:58 am
Hello. I would be interested in the headlight vacuum check valve and the horn relay if they are available and in working order. Thanks.
Postby Doc Hubler » Sun Nov 15, 2015 11:10 am
Lew, I have a set of the splash guards for my 67 that I want to reproduce so others can get these. I just don't have a reasonable source yet. Most people need these, especially the corner pieces tend to get broken off. Also, there is the rubber air dam that connects to this, and there are rubber splash guards behind the front wheels which I have patterns for. I've made these for my car.
Postby Otto Skorzeny » Sun Nov 15, 2015 4:13 pm
I need the ones behind the front wheels. Did you pour them into a mold? Can you make more?
Postby Doc Hubler » Mon Nov 16, 2015 10:59 am
Otto,
The ones behind the front wheels are essentially a piece of rubber cut to fit. There are 2 bolt holes if I remember correctly (i have the pattern and made a couple of sets). One bolts to the bottom inner fender, while the other bolts to the frame. Check your car out. These usually get ripped off either through use or by mechanics working on the cars over the years. They were actually pretty flimsy, not very thick rubber, so most didn't survive. I'm also not sure they were that effective in preventing splash from the front wheels.
There are the hard plastic corner pieces in front (have cutouts for sway bar in front). The center piece is a large plastic piece with the large air dam rubber piece stapled to that (it then connects to front bumper). The large plastic piece and the side pieces (a continuance of the center piece essentially) are frequently broken. I have the part numbers for those as well.
It took me a while to figure these out and find patterns for the pieces, but I have a complete set of all. Just need to find a way to reproduce them at reasonable cost (that's the really tough part!). I have cut out the large air dam pattern as well from the same rubber sheet used for the rear splash guards. These are very large pieces.
Postby Otto Skorzeny » Mon Nov 16, 2015 12:15 pm
Hi Doc,
The hard plastic ones on the front of mine are intact and in good shape on my car. One side has a crack but otherwise complete.
I didn't know the rear ones were masticated rubber (like what mud flaps for trucks are made from).
Would you be willing to mail me tracings of the rear ones so I can make my own? Or maybe post a photo with scale drawings and measurements if they aren't too complex..
Return to “For Sale: Parts”
