Hi,
i have a little problem with my 70 Toronado: The A/C and heater works fine but no matter what i do it only blows out of the lower center opening heating/cooling my feet.
Does anybody have an idea?
Regards
Thomas
A/C only blowing out of lower openings
rollerball
- Years Owned: 1966, 1970, 1974, 1977
1977 Cutly
- TOA Membership Number: 1059
- Years Owned: 1966 Toronados
1977 Cutlass Supreme
Re: A/C only blowing out of lower openings
Have you tried poking with a coat hanger and see if there is a rodents nest blocking your comfort?
waterzap
- TOA Membership Number: 1058
- 1978 Eldorado
I had a similar problem once with a 76 Seville. The actuators in the dash work by vacuum. Took me a long, long time to figure everything out. You might have to check the actuators, and also check if you do get vacuum to them.
1977 Cutly
waterzap wrote:I had a similar problem once with a 76 Seville. The actuators in the dash work by vacuum. Took me a long, long time to figure everything out. You might have to check the actuators, and also check if you do get vacuum to them.
Now that you mention it, my 77 cutlass only blew onto the floor until I found a vac line that wasnt hooked up. Then I could use the defrost.
do you hear any hissing from behind the dash when you move the HV AC controls?
