Is the front horizontal shock the same as the rear ones?
TOA Membership Number: 839
Postby Twilight Fenrir » Wed Aug 04, 2010 9:10 pm
Well, pretty much the topic, is the horizontal shock absorber in the front-end the same as the two in the rear? Or is there a different model for that?
69W34
Re: Is the front horizontal shock the same as the rear ones?
Postby 69W34 » Wed Aug 04, 2010 10:02 pm
I think you referring to the vertical front and rear shocks and they are different the horizontal shock are only used in front of the rear axle. Then I believe there are 2 styles of vertical rear shock on the 66, an (early) and a (late) the later style continued through 70
Postby Twilight Fenrir » Thu Aug 05, 2010 10:24 am
69W34 wrote:I think you referring to the vertical front and rear shocks and they are different the horizontal shock are only used in front of the rear axle. Then I believe there are 2 styles of vertical rear shock on the 66, an (early) and a (late) the later style continued through 70
Naw, I was just looking through my service manual, there's a horizontal shock behind the steering mechanisms according to the book. MOunted right underneath the relay rod, near the PItman arm. Book calls it a "Steering linkage Shock absorber"
69W34
Postby 69W34 » Thu Aug 05, 2010 1:25 pm
Ooooo ... the steering damper :oops: Sorry .... yeah its all by its self and a one year application.
Toronado66
TOA Membership Number: 7
Postby Toronado66 » Tue Feb 08, 2011 8:25 pm
Twilight Fenrir wrote:Well, pretty much the topic, is the horizontal shock absorber in the front-end the same as the two in the rear? Or is there a different model for that?
No.
But still pretty easy to get. I found mine on eBay. Used on Cadillacs and a few other cars...
Darwin Falk
TOA#7
Postby Twilight Fenrir » Wed Feb 09, 2011 6:26 am
Yup, I found one on autozone's website pretty cheep.
1977 Cutly
TOA Membership Number: 1059
Years Owned: 1966 Toronados
1977 Cutlass Supreme
steering damper
Postby 1977 Cutly » Mon May 19, 2014 8:52 pm
I just got one off of Rock auto. How tough to install when it gets here?
Users browsing this forum: Google Adsense [Bot] and 21 guests
