66 turn signal flasher?
followme21
Years Owned: 66 toronado
Postby followme21 » Wed May 22, 2013 1:04 pm
Where is the turn signal flasher located, at least I think thats my problem, all bulbs light up but no flash.
Also on maybe a related note all of a sudden my dash lights stoped working. I checked the fuse and its got power to one side of the fuse, but as soon as I pug in the fuse the power goes away, its a good fuse. And if I jump from power to the dead side of the fuse the lights work.
Any thoughths?
waterzap
TOA Membership Number: 1058
Years Owned: - 1967 Toronado
- 1978 Eldorado
Re: 66 turn signal flasher?
Postby waterzap » Sun Jun 02, 2013 7:15 pm
On my 67 its in the fuse panel. Big round thing.
oltoronut
Years Owned: 1966 toronado
Postby oltoronut » Wed Jul 17, 2013 1:21 pm
The flasher is located under the steering wheel.. Take off the left panel under the dash cluster
where the brake release is. It clips in a slot in the panel...
I just put a heavy duty flasher in since I put a sequencer in to sequence the signal lights.
Daniel516
Postby Daniel516 » Tue Oct 28, 2025 3:05 am
Je comprends ce genre de galère mécanique, surtout quand un petit composant comme un clignotant peut bloquer tout le tableau de bord. Pour me changer un peu les idées après ça, j’ai testé https://spin-mama.fr, un casino en ligne pour les joueurs de France. Au début, j’ai perdu quelques tours sur les machines à sous, mais ensuite un gros gain inattendu est tombé et a complètement changé la session. Comme pour réparer une panne, il faut parfois un peu de patience et d’essais avant d’obtenir le résultat satisfaisant
