Is the front horizontal shock the same as the rear ones?
Well, pretty much the topic, is the horizontal shock absorber in the front-end the same as the two in the rear? Or is there a different model for that?
Re: Is the front horizontal shock the same as the rear ones?
I think you referring to the vertical front and rear shocks and they are different the horizontal shock are only used in front of the rear axle. Then I believe there are 2 styles of vertical rear shock on the 66, an (early) and a (late) the later style continued through 70
69W34 wrote:I think you referring to the vertical front and rear shocks and they are different the horizontal shock are only used in front of the rear axle. Then I believe there are 2 styles of vertical rear shock on the 66, an (early) and a (late) the later style continued through 70
Naw, I was just looking through my service manual, there's a horizontal shock behind the steering mechanisms according to the book. MOunted right underneath the relay rod, near the PItman arm. Book calls it a "Steering linkage Shock absorber"
Ooooo ... the steering damper
Sorry .... yeah its all by its self and a one year application.
Toronado66
- TOA Membership Number: 7
Twilight Fenrir wrote:Well, pretty much the topic, is the horizontal shock absorber in the front-end the same as the two in the rear? Or is there a different model for that?
No.
But still pretty easy to get. I found mine on eBay. Used on Cadillacs and a few other cars...
Darwin Falk
TOA#7
Yup, I found one on autozone's website pretty cheep.
1977 Cutly
- TOA Membership Number: 1059
- Years Owned: 1966 Toronados
1977 Cutlass Supreme
steering damper
I just got one off of Rock auto. How tough to install when it gets here?
